Nitrous Oxide Too soon, jr.
What is a safe but powerful shot to run on stock engine
Old Dec 28, 2004 | 09:42 PM
jake-trackpack's Avatar
jake-trackpack
Default What is a safe but powerful shot to run on stock engine
I have a stock 350z, What is the biggest shot i can run safely? Right now i'm running a 75 wet shot ZEX system.
Old Dec 28, 2004 | 09:43 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Default Re: What is a safe but powerful shot to run on stock engine
I dyno tuned with a 75, but I have seen many run 100 and a few run 125
Old Dec 28, 2004 | 09:47 PM
jake-trackpack
Do you know if they had to back off the timming?
Old Dec 28, 2004 | 10:59 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I am not sure what you are referring to. My dyno tune or the other guys? As far what I have heard, Nitrous users are not allowed to advance the timing too much since you do not want the engine to blow
Old Dec 29, 2004 | 07:38 AM
omarv6's Avatar
omarv6
I thing Noz is thy way am gono go .... turbos and chargers ar cust too $$$$ and not safe as I can see ....so all keep my car NA with the most mods i can for NA HP .......and when racing Nos will come to help
Old Dec 29, 2004 | 10:40 AM
southern_info's Avatar
southern_info
I really dont' know much about nitrous system except for when you hit the button you suppose to gain some extra horsepower. How many hp have you gain from the 75 shot and how many seconds do you spray a total amount of? What gear do you start spraying?
Old Dec 29, 2004 | 02:24 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
N2O definitely adds power. Just some FYI i gained about 121 FT/LB of torque down low on a 75 shot compared to my N/A run
Old Dec 29, 2004 | 05:44 PM
TheBigShow's Avatar
TheBigShow
yes, sir!!!
Old Dec 29, 2004 | 11:21 PM
jake-trackpack
I heard that any kind of big shot say greater then 50 you have to back off the timming,what i'm wondering is do i have to back it off with 125 or 150 and if so how much? also do i have to do any mayjor engine work to run that kind of shot?
Old Dec 30, 2004 | 02:51 PM
mrtomcat's Avatar
mrtomcat
75 shot is fine but I'd recommend using it with 103 octane gas only. And you defenetely need colder plugs
Not sure about anything above though on a stock engine
Old Dec 31, 2004 | 12:50 AM
jake-trackpack
See i put 1 step colder plus in already, also a 15lbs bottle , bottle heater, so i just need more power
Old Dec 31, 2004 | 06:10 AM
TheBigShow's Avatar
TheBigShow
i haven't heard of anyone cuttin timing.
Old Dec 31, 2004 | 06:30 AM
mjedens's Avatar
mjedens
Default Timing
I take timing out with the eManage.
Old Dec 31, 2004 | 06:33 AM
TheBigShow's Avatar
TheBigShow
your shot is a little more than a 75 though, isn't it?
Old Dec 31, 2004 | 07:13 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I read I think in the big bad nitrous post that the ecu can take up to 4 degrees of timing out on it's own, which should be good up to 100hp shot. -1 degree for every 25 hp shot. You do need one step colder plugs though for sure.
Old Dec 31, 2004 | 08:15 AM
mjedens's Avatar
mjedens
Default Timing
The trick is taking it out when you want to!!!
TheBigShow: Shot size= 150 to 225. I feel you probably don't need to retard timing unless you are in that area as long as you have a good AF, 100 octane, and 1 or 2 degree colder plugs.
Old Dec 31, 2004 | 08:21 AM
TheBigShow's Avatar
TheBigShow
i was plannin on doin a 75 shot on 93 octane with 1-step colders; sound good?
Old Dec 31, 2004 | 08:31 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Im running the same setup with 91 octane
Old Dec 31, 2004 | 03:00 PM
mrtomcat's Avatar
mrtomcat
be very careful with that, the minimum safe recomendation for nitrous is 92 octane. At least ad some Chemical X to boost the octane
Old Dec 31, 2004 | 05:26 PM
jake-trackpack
75 shot is fun but i need bigger. I think i'm going to go at least 125, what is this eManage?
