Nitrous Oxide Too soon, jr.
Anyone run N2O with 3.91s?
Old Oct 12, 2006 | 07:08 PM
Metal Heart's Avatar
Metal Heart
Default Anyone run N2O with 3.91s?
Just wondering if anyone has done it and what the results were?
I'm planning on doing it with a set of Drag Radials for the strip. I figure it should cut me down to low 11s with the 150 shot and UTEC, but I'd like any input.
Old Oct 12, 2006 | 07:15 PM
MikeEwithTheZ's Avatar
MikeEwithTheZ
i am going go that wat but i dunno the results
Old Oct 13, 2006 | 03:03 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i would get new axles, i was pushing the luck with them on slicks and a 150 shot. honestly, i think that with those gears and drag radials you will never hook up. you need some et drags (real slicks) or you will just be spinning everywhere. i think that you would barely be able to break into the 11s with that setup. you would have plenty of power, just the traction wouldnt be there... good luck either way ryan
Old Oct 13, 2006 | 11:48 AM
Metal Heart
hmmm...what size DRs were you running Jeremy?
I'll consider the axles, but I think they'll be a "replace it when it breaks" type thing.
Old Oct 20, 2006 | 06:21 PM
Mc556's Avatar
Mc556
Just a thought but since you would probley have bad traction issues on the launch what does everyone think about locking out and not spraying first gear?
I haven't got the chance to use it yet but I bought the dynotune combo switch that you can do that with and thought it might work great on this type of setup.
Old Oct 21, 2006 | 06:19 AM
QuadCam's Avatar
QuadCam
you need to spray in 1st if you want a decent ET. The 1/4 mile is made in the 1st 60'.
Old Oct 21, 2006 | 04:55 PM
Mc556's Avatar
Mc556
I agree with the last part but in some cases less is more. I don't think were going to see any sub 1.40s on a Z with drag radials.
On one of our big block nitrous cars we were faced with rules that only allowed single stage plate systems and stock suspension mounting points. That wasn't so bad except that we only allowed to run M/T et drags in 26x10-15 per class rules. That year we ran a best ET of 5.46 in the 1/8th. Next season we were allowed to use a progressive controler and running the same exact setup(no refresh on motor) and ran a best of 5.39. Same max shot at 250 but delayed by an .8th from 125.
A few of you might think .07 isn't much but on a 5sec car (1/8th) it's huge.
Sorry I ramble but I honestly don't think his setup will make use of a 150shot unless he is on full slicks or makes use of some sort of delay be it a first gear lockout or something time delayed.
Old Oct 30, 2006 | 02:18 PM
Metal Heart
I'd be using UTEC so... you can control the RPMs/gear if need be.
I suppose we'll just have to test/play with it.
Old Oct 30, 2006 | 07:40 PM
one350zfan's Avatar
one350zfan
I don't think you can lock out just one gear with the utec, or specify different RPM windows in different gears. If you do a 150 shot on slicks and practice, 11.5 should be had without a 3.9 gear. Plus, you definitely wouldn't be able to use it on the street IMO.
Old Nov 5, 2006 | 04:22 PM
rocks's Avatar
rocks
You can get that maximizer nitrous controller and it does gear lockout.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
