Nitrous Oxide Too soon, jr.
Nitrous, Wet? Dry? Wet/Dry? opinions?
Old Apr 2, 2003 | 07:13 PM
ZFlyer's Avatar
ZFlyer
Default Nitrous, Wet? Dry? Wet/Dry? opinions?
Just wondering which is better/safer to use. I hear the wet systems produce more hp. Is this true? I ran a NX Wet/Dry system (sprayed both fuel and N2O into the intake) on my Camaro a few years back, and had no problems. Just wondering if I should go with a wet or dry system for the Z.
-Bryan
Old Apr 2, 2003 | 10:06 PM
BootieMAN's Avatar
BootieMAN
Dunno if the wet systems give out more hp, but from what I've heard and read is that the wet system is the way to go. I'm running NOS and I know a couple other members here are running it as well as some Zex setups.
-BootieMAN
Old Apr 3, 2003 | 07:42 AM
2003z33's Avatar
2003z33
Go Wett!..
Old Apr 3, 2003 | 09:20 AM
franklinz's Avatar
franklinz
dont know all the terminology, but id tap into each runner as this will equally distribute the nitrous into each cylinder.
rather than dumping it into the throttle body and letting the vaccuum suck in varied amounts.
franklinz
btw: when do i get to use a custom avatar???
Old Apr 3, 2003 | 09:22 AM
DarkTalon's Avatar
DarkTalon
A wet system is preferable if you are running a big shot (+75hp) due to the need of more fuel.
A dry system is OK for small shots. You can ask to a technitian from the system's company about the different options and his recommendation.
Old Apr 5, 2003 | 12:10 PM
dubcac's Avatar
dubcac
If you want the ultimate in versatility and reliability, go with a Direct Port setup where each intake runner has it's own nozzle spraying fuel and nitrous. It takes care of distribution problems at higher HP level shots of the giggle gas.
Old Apr 5, 2003 | 12:47 PM
2003z33's Avatar
2003z33
Have you seen anyone with the NOZZLE type injection?
Old Apr 5, 2003 | 03:41 PM
dubcac's Avatar
dubcac
I have seen it, but not on the Z. It is basically the same as a direct port kit, but does not require drilling the intake manifold. The cost however is pretty substantial compared to a conventional direct port kit.
wanderingstuden
Jan 28, 2016 07:03 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
