Nitrous Oxide Too soon, jr.
MSD RPM Window Switch Question
Old Nov 10, 2003 | 05:17 PM
alex30327's Avatar
alex30327
Originally posted by 02trex
89561 is the switch I have. When I first talked to MSD because I could not get the switch to operate, they told me different ways to hook it up and that it should work. Then, after a "tip" I contacted Ruebin at MSD and was informed that the switch would NOT work. Call MSD and ask for Reubin. I sent mine in to them and should be receiving it back next week.
Does yours have the Dis-Ras words on it. Mine says on the box that it will work with 1 cylinder? Maybe I need to call Reubin. This sucks, becuase I already installed it. I'll let you know if it works.
Old Nov 10, 2003 | 06:43 PM
02trex's Avatar
02trex
Yes, we have the same switch. According to MSD, despite being for 1 cylinder operation, the voltage is the issue. The switch is not designed for the voltage that our cars see.
89561 requires modification for voltage
8956 requires modification for voltage and cylinder
Old Nov 14, 2003 | 07:22 AM
alex30327's Avatar
alex30327
I talked with Reubin at MSD. Thanks for the advice! Apprently they brought a Z into the shop yesterday to test the 8956 and 89561 RPM window switches. I was told that the 89561 switch would not work with the Z, and that I needed to have the regular 8956 switch and that it needed to be modified. Luckily I have both swithces, so I am sending mine off today to get the modification.
Old Nov 17, 2003 | 07:47 AM
02trex's Avatar
02trex
These MSD jerks can't make up their minds. I just spoke to them (Ruebin) and was told that the 89561 would work once modified, but that the 8956 would be simpler to modify.
I received mine back from them on Friday and will try to install soon.
Old Aug 25, 2006 | 06:46 PM
Ohiodan's Avatar
Ohiodan
are there any other rpm window swithces that will work without having to modify it?
Old Aug 27, 2006 | 10:08 AM
MySunset350Z's Avatar
MySunset350Z
this is an old thread.
just buy the digital msd rpm window switch (no pills) and install it according to their 1 cylinder setup. to get an rpm reading all you need to do is tap into one spark wire off of any cylinder and you're done with the hard part.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
issyz
Jul 2, 2017 03:04 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
