Nitrous Oxide Too soon, jr.
The big bad nitrous post
Old Aug 1, 2003 | 04:05 AM
  #181
Edretti's Avatar
Edretti
Well I am up and running. I blew the ecu main fuse which is hidden under the wiper cowl panel. I am up and spraying and very happy with the install. Check out the thread I posted in the G35/Skyline forum.
https://my350z.com/forum/showthread.php?s=&threadid=38082
Old Aug 1, 2003 | 04:06 AM
  #182
Edretti's Avatar
Edretti
https://my350z.com/forum/showthread....threadid=38082
Old Aug 11, 2003 | 05:26 AM
  #183
02trex's Avatar
02trex
Default G-Tech comparison
For reference only!
14.03 @101.2 no juice
12.87 @ 109.8 spraying ZEX jetted for 125 rwhp
I need to get to a real track soon!
Old Aug 11, 2003 | 05:55 AM
  #184
Jspec350z's Avatar
Jspec350z
Nice gains. I wonder how accurate those G-tech meters are. Has anyone taken one to the track and tested it?
Old Aug 11, 2003 | 12:07 PM
  #185
Edretti's Avatar
Edretti
Wow 02 trex! I hope that G tech is at least close. Notice a big difference between the 100 and 125hp jets? I got mine in on Friday night and I'm very pleased. I'm hoping to crack the 12 barrier sometime soon. I guess I'll find out @ MIR on the 7th. Hope you can make it.
Old Aug 11, 2003 | 04:59 PM
  #186
12SecZ's Avatar
12SecZ
THE ET is usually fairly accurate although it traps high regurlay.
I had one and they work fairly decent except for the trap speed.
Old Aug 12, 2003 | 02:41 AM
  #187
02trex's Avatar
02trex
The ET is supposed to be accurate to within 5/100 of a second, but it takes into consideration things such as how level the road is that you're testing on when it calculates your time... variable. MaxHax is correct regarding the trap speed; anyone I've spoken with about the device states that the trap speed is higher than at the track.
I did not test the 100 shot jet combo using the G-Tech so I can't quantify the difference between 100 and 125; I will say that the 125 shot jet combo along with the Z intake duct "felt" very sweet.
Old Aug 12, 2003 | 07:24 PM
  #188
Jspec350z's Avatar
Jspec350z
What plugs are available now? The densos and the ngk? anything else? for a 100 shot should I go 1 range cooler or 2?
Old Aug 12, 2003 | 08:33 PM
  #189
12SecZ's Avatar
12SecZ
2 if you can find them but I could only find one degree
PL-FR6A-11. Someone said (heresay) that Denso makes a nice 2 heat range plug but stick with copper for the best performance, they are cheaper too. I am assuming the PL is platinum 6 will set you back 90 bucks! 6 coppers should be like 6 each if you can hold out NGK has them on back order!
My 2 cents
cha ching!
Old Aug 12, 2003 | 08:50 PM
  #190
Jspec350z's Avatar
Jspec350z
https://my350z.com/forum/showthread....ighlight=denso
I may just have to go for these then kinda pricey you ask me but what am I going to do. We are stuck!! Thanks Nissan!
Old Aug 12, 2003 | 09:46 PM
  #191
12SecZ's Avatar
12SecZ
Nah I found copper PM me for the part # 5 bucks each.
Old Aug 14, 2003 | 11:45 AM
  #192
Jspec350z's Avatar
Jspec350z
Found my Nitrous Bottle!!! Tell me this thing doesn't look great. I talked with ZEX and found this bottle to be the same as they sell!! Just the right color!
Electric Blue Bottle
Old Aug 14, 2003 | 05:45 PM
  #193
12SecZ's Avatar
12SecZ
that's a sweet piece there.
is it 4-an or 6-an I didn't notice but you can buy adapters for 6 bucks
Old Aug 15, 2003 | 08:41 PM
  #194
Jspec350z's Avatar
Jspec350z
They use a CGA 326 valve the same one Zex uses!! so it is 4an I guess!! Well at least I hope.
Old Aug 16, 2003 | 05:29 AM
  #195
12SecZ's Avatar
12SecZ
Yeah ZEX is 4-an NOS is 6-AN, cool!
Old Aug 18, 2003 | 08:48 AM
  #196
MySunset350Z's Avatar
MySunset350Z
Question
oook...
i just ordered the nx kit today. i got a few extra's too. man does that stuff add up.
any way here's what i got...let me know if i'm missing anything.
the nx nitrous kit....up to 150shot
auto bottle opener
dual purge (for show)
open throttle switch
they were selling another kit. some gen-x kit where it had a heater, gauges, shutoff valve, safety stuff etc. should i get that or is it a waste?
i dont mind putting down $300.00 for this kit if it means i'll have peace of mind, but is it worth it or am i worrying too much?
waitin on ur reply max.
oh and what should i do about my stock plugs...where can i get colder plugs at?
Old Aug 18, 2003 | 03:53 PM
  #197
12SecZ's Avatar
12SecZ
If you plan on racing the heater is essential if you do not race reguarly it is not.
Also for racing (legal) you will need what is called a blow down tube. If the bottle pressure reaches above 1500psi in the heat it will disperse. It contains sulphar and will make you VERY sick. They add sulphar so people can't abuse it (get high off it.)
According to NHRA specs (National Hot Rod...) the N20 must vent either into a trunk or to atmosphere. It's 20 bucks and worth it you can vent it out a plug hole in you trunk.
Option B is the pressure release valve. This just blows a seal and vents it into your car. Not good but better than a pressuirized bottle w/o no vent at all.
Either option would be MANDATORY for me, I know a guy who blew his on the track and coughed and etc and was very sick for a long time. So don't listen to people who say it will never happen.
I know my ZEX bottle didn't come with A or B for venting not sure about NX but I would check.
I hope this helps. Without the BD Tube you will not pass tech at the track if they see you purge and know you have N20. FYI.
Old Aug 18, 2003 | 03:55 PM
  #198
12SecZ's Avatar
12SecZ
Plugs
missed that, NGK has plugs for platiinum or copper now. The copper is not only better but cheaper. The part number is around this thread or the SC one somehwere I used to have it on my desk.
Old Aug 18, 2003 | 04:01 PM
  #199
jesseenglish's Avatar
jesseenglish
NGK lfr6a-11 but good luck finding them. The only place I could find them locally was at a Yamaha boat dealer. Those plugs are used in the F115ATL 115hp outboard motor. They were $6.36 each, much cheaper than platinum plugs.
Old Aug 18, 2003 | 04:09 PM
  #200
CarFanatic's Avatar
CarFanatic
all nitrous kits have burst disks in the bottles. If it reaches over a certin psi the disk will pop and vent the n2o out.
