Nitrous Oxide Too soon, jr.
The big bad nitrous post
Old Jul 4, 2005 | 10:10 AM
  #261
QuadCam's Avatar
QuadCam
i looked at that too, but i decided on the NX wet kit.
i didn't like the looks of the edelbrock dyno graphs. look at what is happening on the high end of the rpm scale! the power shouldn't be falling off like that.
Old Jul 17, 2005 | 12:08 AM
  #262
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
ok so the zex kit dosnt come with a bottle mouting bracket? also will the zex kit work with the nx maximizer? i cant believe there has been no talk about the maximizer it gets rid of your windoswitching crap and you can dial in when you want to spray.. also i hear you can couple it with a wideband 02.. this is my plan anyways.. untill someone tells me differently
Old Jul 17, 2005 | 09:33 AM
  #263
reboot04's Avatar
reboot04
Nitrous Express website says that the maximizer has been discontinued...anyone know more about this?
Link: http://www.fjoracing.com/products/Maximizer/nxmax.htm
Old Jul 17, 2005 | 10:54 AM
  #264
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
"*** Please note that while we are continuing support for the NX Maximizer, this product has been discontinued and is superceded by the new Maximizer-II which features enhanced capabilities and features. for details."
Old Jul 17, 2005 | 04:43 PM
  #265
reboot04's Avatar
reboot04
Thanks...sometimes I stop reading way to soon.
Old Jul 19, 2005 | 02:37 PM
  #266
Gators2001's Avatar
Gators2001
HOLY CRAP!
I just bought this thing and now a new and better one is coming out my luck.
Old May 12, 2006 | 08:50 AM
  #267
Fluid1's Avatar
Fluid1
I have a question for the nitrous guys..... with a wet kit, it would be a good idea to have the nozzle spraying directly into the neck of the penelum? I only ask because I'm about to run a 100 wet shot into the bottom of the neck of the aftermarket larger penelum and want to be sure there's not going to be a pooling issue..... thanks
Old May 12, 2006 | 09:45 AM
  #268
MySunset350Z's Avatar
MySunset350Z
you dont have to mount it on the plenum. mount it as close to the plenum as possible, but mount it on the intake. this way if you ever sell the plenum, you wont have to worry about a hole being in it. its also easier to remove the intake then to remove the plenum. pooling is a problem only when you mount the fogger far down in the intake (6inches+) where the shot has time to heat up and condense, or when bottle pressure is too low and the fuel does not vaporise properly. pooling can also happen when you leave nitrous in the main feed line for a long period of time and air builds up in it. this way when you spray, the fuel again wont vaporize properly and will pool and cause a backfire. a purge kit will take care of the air build up.
good luck.
Old May 13, 2006 | 06:31 PM
  #269
QuadCam's Avatar
QuadCam
Originally Posted by Gators2001
HOLY CRAP!
maximizer II has been out for quite awhile
Old May 13, 2006 | 10:01 PM
  #270
Gators2001's Avatar
Gators2001
that post is nearly a year old.
Old May 14, 2006 | 05:39 PM
  #271
Audible Mayhem's Avatar
Audible Mayhem
My350z
andrew.... look at the date on that one... hehehe
Old Jun 15, 2009 | 12:05 PM
  #272
TitaniumZ's Avatar
TitaniumZ
Originally Posted by DarkTalon
I read your previous post on nitrous and there is posted that people with the Venom system had problems because it was a dry system and were pushing it too hard.
The Venom system is not "entirely" dry because although it only has a single input nozzle the electronic control module taps into the injector harness and it modulates the injector signal making them to flow more fuel. So it can be sais that it's a "semi-wet" system. It's true that the Venom is a little expensive but it takes out the problem of jetting as the system uses pre-measured nozzles to inject the nitrous.
IMO the best is the ZEX system b/c of its simplicity and clean install.
It is the most basic and unreliable in my opinion Nitrous Express is your safest bet plus the have an awesome window switch
Old Jun 15, 2009 | 12:39 PM
  #273
New JerZ's Avatar
New JerZ
th th th th th thread resurrection!!!!!!!!!
Old Jun 15, 2009 | 10:26 PM
  #274
BakaN20's Avatar
BakaN20
Hey, at least we know people are searching when they bring up threads from a couple years ago, lol
Old Jul 22, 2010 | 06:23 AM
  #275
Coolwest2010's Avatar
Coolwest2010
about how long would a 10LBS bottle last?
Old Jul 22, 2010 | 07:16 AM
  #276
oneslowz's Avatar
oneslowz
depends on what shot your using
Old Jul 22, 2010 | 10:46 AM
  #277
QuadCam's Avatar
QuadCam
with a typical 100 shot....you'd probably be looking at being able to make about 3 full 1/4 mile passes before you start having major pressure drops by the end of the run.
If you are talking just little squirts of the juice around.....hard to say how long a 10# bottle will last.
Old Jul 24, 2010 | 01:34 PM
  #278
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
How long a 10 lb bottle lasts depends on the ambient temperature, your nitrous jet size, the duration of your sprays, your nitrous line length, etc.
For the most part, QuadCam is correct in that you only get a few, full passes with a 10 lb bottle.
Old Aug 2, 2010 | 07:15 PM
  #279
krazyrican76's Avatar
krazyrican76
Originally Posted by McDan
Other side, better view of elbow fitting.
Where can I purchase this item?
Old Aug 16, 2010 | 04:06 PM
  #280
Stock2Autocrozz's Avatar
Stock2Autocrozz
Confused over NA mods to bring starved front 2 cylinders AIRFLOW up a bit...anyone experience different results with stock vs Kinetix SSV or possibly thicker like APS for FLOW?
