Nitrous Oxide Too soon, jr.
Is the bottle safe in hot weather?
Old Aug 29, 2007 | 02:37 PM
Hybrid90's Avatar
Hybrid90
Default Is the bottle safe in hot weather?
For you nitrous guys.. do you ever leave the bottle in the car when it's like 95 degrees out like right now in Cali? Is it safe? Although you have a blowdown tube.. is it safe or will too much pressure make it blow through the blowdown tube?
Old Aug 29, 2007 | 02:46 PM
go-fast's Avatar
go-fast
if pressure is to high the tank will vent ,without a vent tube it will purge inside your car,95 degrees outside is like 140 in car with windows up.if you are not using nitrous take out tank.
Old Aug 29, 2007 | 03:44 PM
coachk's Avatar
coachk
Probably stupid for me doing this but I have been leaving my bottle in my car in the driveway(windows up) in 95 degree weather.I've checked it each day at 4pm to see what the bottle pressure is and its consistantly 1160....I guess my experiment is over so since I only use the N20 at the track, the bottle is now out.
Old Aug 29, 2007 | 05:00 PM
jksstar's Avatar
jksstar
I leave mine in the car, but I will put some ice on them after a few hours.
No way I will take my bottles out, never know what may pull up along side you
Old Aug 29, 2007 | 05:26 PM
one350zfan's Avatar
one350zfan
If direct sunlight hits the bottle, it can and will break the burst disk.
When my bottle is full, bottle pressure can reach 1300-1400 psi and possibly more. I carry a small white towel which I cover the bottle with if direct sunlight is a problem.
I have a blow down tube installed so its not a safety concern for me but losing $30 worth of NO2 sucks... from what I gather...
Last time at the track it was hot and I couldn't get the pressure below 1200 psi on the bottle. I used the towel and a/c to cool it. My data log runs are with 1000-1100 psi in the bottle. I was concerned running at 1200 psi because in theory it would run lean(more pressure= more NO2)
Old Aug 29, 2007 | 07:35 PM
RedondoG's Avatar
RedondoG
Last time I was at the track it was 104 at 2:00 and my bottle pressure was at 1300 PSI. It locked up my purge valve but once I hit the juice everything freed up. best run that day was at 2:00 13.88 @ 107 mph.
Old Aug 29, 2007 | 07:48 PM
Hybrid90's Avatar
Hybrid90
Well good to hear that none of you guys blew up haha. I was just curious because it's hella hot today in Cali... thanks for the replies
Old Aug 30, 2007 | 04:39 AM
skwid's Avatar
skwid
I have a NX Bottle Blanket... It's been 100+ here and I've never had it pop the seal. It occasionally locks up the purge when it hit's about 1300 psi but that's rare.
Old Sep 1, 2007 | 01:33 PM
Integrity's Avatar
Integrity
Just an FYI for some of you guys in hot areas like Cali and FL. There's a company that makes a fully enclosed nitrous temperature control system.
Here's a link.
It supposedly will heat OR COOL your bottle to keep it in the exact temperature range you want it to. I don't know if it works, only that its kind of expensive ($360) and would demand quite a bit of room in your trunk. Just thought I'd let you guys know about it since it was news to me when I saw it.
Old Sep 17, 2007 | 01:45 PM
jolt3500's Avatar
jolt3500
OMG those things look ridiculous!! hahaha
Old Sep 25, 2007 | 10:38 PM
GFrnk69's Avatar
GFrnk69
+1
Old Sep 26, 2007 | 02:20 PM
Bam-0's Avatar
Bam-0
what about vegas 120 degree heat?
Old Sep 27, 2007 | 04:27 AM
QuadCam's Avatar
QuadCam
the burst panel on the bottle valve has a very high rating....I don't remember, but I think it is over 3000 psi. I normally filled bottle will not reach those pressures even in hot areas.
The only time I ever had a burst panel pop on me was because I was a jackhole and I overfilled my bottle. I was in a hirry, and I didn't use a scale while filling it. I actually put 14# of nitrous in a 10# bottle. That alone didn't do anything, but I left my car outside in the florida summer heat (high noon) for about 4 hours or more. When I got back to the car, the bottle was empty. . That's when I noticed the that the burst panel let go.
Old Sep 27, 2007 | 04:43 AM
go-fast's Avatar
go-fast
at least you were parked,it would've been ugly if you were driving down the street.did you add a blow down tube before or after that experience?
Old Sep 27, 2007 | 07:33 PM
QuadCam's Avatar
QuadCam
no blow down tube......it would have scared the hell outta me if I were in the car. The car would have smoked up like a Snoop Dogg video.
Old Sep 27, 2007 | 08:35 PM
go-fast's Avatar
go-fast
you could pass out and crash,the sulfer alone might make you puke....puke in your car sucks!you should add a tube it's cheap insurance.
bcoffee20
Nov 19, 2015 06:39 PM
SharX59
Sep 30, 2015 10:54 AM
FromGtoZ
Sep 20, 2015 03:41 PM
