Nitrous Oxide Too soon, jr.
Hitting The Rev Limiter
Old Dec 19, 2007 | 08:16 PM
VQTURBODREAMS1's Avatar
VQTURBODREAMS1
Default Hitting The Rev Limiter
If you have a fuel pressure safety switch and you hit the rev-limiter it cuts fuel.. but since you have the fuel pressure safety switch once it cuts fuel shouldnt it cut the nitrous.. So therefore you wouldnt blow your motor.. This makes sense on paper at least.. any feedback??
Old Dec 19, 2007 | 08:39 PM
go-fast's Avatar
go-fast
if the nitrous solenoid is powered off of the fuel pump relay it will cut fuel and nitrous
Old Dec 20, 2007 | 04:15 AM
skwid's Avatar
skwid
Yeah, you need to make sure you cut both nitrous and fuel with the switch.
Old Jan 10, 2008 | 11:37 AM
Q45tech's Avatar
Q45tech
Important to measure the exact delay between commanding a solenoid to shut off and the time the flow stops AND the number of engine rpms in the 1/10 second about 12 rpms........the gasoline/nitrous mass relationship so that the lighter nitrous does flow when fuel is stopped.
Old Jan 10, 2008 | 01:39 PM
VQTURBODREAMS1
i had mine installed at a shop and they told me i didnt have to worry about the rev limiter but im going to eventually put a rpm activator in and start sprazying but that sounds complicated..
Old Jan 12, 2008 | 03:07 PM
TeAm PrOSpEc's Avatar
TeAm PrOSpEc
trust me if you use a wet system you dont have to worry about the rev limmiter. I accidently tap the rev limiter a couple of times while spraying and it didnt do anything. You already have fuel being sprayed into the motor via selinoid. When the ECU cuts fuel it happens @ the injectors not @ the fuel pump. so your good!
Old Jan 14, 2008 | 10:29 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Either way, it still is starving for fuel, which is a lean condition.
Old Jan 15, 2008 | 11:40 AM
TeAm PrOSpEc
I dunno buddy...
Old Jan 15, 2008 | 12:08 PM
3hree5ive0ero
Retired Admin
I dunno buddy...
Think about it.
Let's assume that the extra oxygen added by the nitrous is compensated by the extra fuel that is also sprayed with nitrous. If the fuel is cut off, what is compensating for the normal level of oxygen that the engine's already breathing in?
Old Jan 15, 2008 | 01:14 PM
VQTURBODREAMS1
has anyone heard of someone blowing their motor with a 100 shot???
Old Jan 15, 2008 | 01:19 PM
rcdash's Avatar
rcdash
The fuel cut is complete. The cylinder becomes an air pump, which without any fuel will not ignite. This type of "lean" condition will not detonate (since there is no fuel to detonate - at all).
Old Jan 15, 2008 | 05:26 PM
3hree5ive0ero
Retired Admin
Ah, my mistake. I stand corrected.
Old Jan 21, 2008 | 05:25 AM
TeAm PrOSpEc
I like yall .... yall are smart like my self! lol just kidding
Old Jan 28, 2008 | 12:21 PM
Chaser720's Avatar
Chaser720
Lemoned Z
An rpm switch a nessecity. It just provides another saftey feature to keep you from blowing the engine. If you want to depend on the fuel pressure saftey switch your argument sounds legit but for one dont want to be chancing split second cut offs on the life of my engine.
And as far as a 100 shot goes... to safely run that you will need one step colder plugs, UTEC, and tune. Asked Sharif about running a 125 with tune and he said he only felt comfortable tuning a 100.
Old Feb 12, 2008 | 05:51 AM
VQTURBODREAMS1
ive been hearing alot of people saying the 100 shot is pushing it on stock internals also..
Old Feb 16, 2008 | 06:44 AM
Jekukun's Avatar
Jekukun
You can run a 150 shot on stock internals as long as you retard the timing. Audible Mayhem is the guy to talk to about that.
Old Mar 13, 2008 | 07:09 AM
KRRZ350's Avatar
KRRZ350
I couldn't agree more, and not just for fuel cut reasons either..........
I run the msd digital one, it is a very simple install and only cost me around $100 new on e-bay IIRC, alot cheaper and easier than pulling your motor.
Allthough you will lose out on the semi-cool digital tach, and the easy to adjust rpm points, you can also get one from a place called "bakers electronics" for around $40, it comes pre-programmed for the cylinder count (v6 etc) and with one setting (aka on @ 4k off @ 6.5k), or you can get one that has switches to adjust between 8 pre-set on/off threshholds for $50, read my warning thread for the benefits of this. Here is there page http://mysite.verizon.net/vze7erz1/id1.html Site is a tad ghetto but I've been very impressed with there o2 sims.
Now, does anyone have any info on the Z/G's fuel pump limitations? I know of at least one person running a 150shot on a 3.5 a33b maxima, stock internals hold up just fine, but on the a33b's anything past 100 shot and you are entering fuel pump territory.
Old Mar 13, 2008 | 09:24 AM
3hree5ive0ero
Retired Admin
Many people have run 150 shots without upgrading their fuel pump. A couple of people have done the upgrades, but I don't think it's necessary as long as you're 150 or less.
TrboMike
North East
Sep 28, 2015 06:36 PM
