Nitrous Oxide Too soon, jr.
Got Zex kit for cheap
Old Mar 27, 2008 | 10:39 AM
tnk210's Avatar
tnk210
Default Got Zex kit for cheap
The only problem is its a dry kit. How difficult is it to make this a workable wet kit for the Z? I've been reading up on the threads, but there seems like a bunch of way to do it.
Also, I have the Cobb Ap Stage 2 flash as opposed to Utec.
Old Mar 27, 2008 | 11:27 AM
coachk's Avatar
coachk
You would be much better off with a wet kit.....read the sticky for more N20 info
Old Mar 27, 2008 | 12:05 PM
tnk210's Avatar
tnk210
So I can't buy the pieces to make it a wet kit?
Old Mar 27, 2008 | 01:13 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Isn't dry kit basically the same thing, except it just doesn't include the fuel stuff?
If so, all you need is:
-fuel solenoid (wire to the relay for nitrous so it activates at the same time)
-fogger (so it'll mix fuel and nitrous)
-fuel tap
-line for fuel tap to solenoid and for solenoid to fogger
-appropriate jet sizes for both fuel and nitrous
-other adaptors for proper fit
Old Mar 27, 2008 | 01:22 PM
tnk210's Avatar
tnk210
Thanks! That's what I was looking for. Do you know if the nitrous control unit works the same or are they different?
If things are too difficult I'll just sell this dry kit and buy the wet version. I got it for $200 basically brand new so I couldn't pass it up.
Old Mar 27, 2008 | 01:29 PM
3hree5ive0ero
Retired Admin
Actually, because you have the ZEX kit, it may be a different. From what I remember, they have a "brain" control center which has the relay, wiring already done, solenoid, etc. In this case, it may behoove you to just ditch that and get the:
-nitrous solenoid (necessary adaptors, lines, etc)
-relay
-TPS/window switch
Essentially, your kit will no longer be a ZEX kit. You can always sell that and get a premade wet kit (saves you the time consuming process of finding parts and buying and waiting and whatever).
Old Mar 27, 2008 | 01:30 PM
Nexx's Avatar
Nexx
sounds like you should just get rid of it and find the proper kit.
Old Mar 27, 2008 | 02:18 PM
tnk210's Avatar
tnk210
I agree. Thanks guys.
Old Mar 27, 2008 | 09:47 PM
MySunset350Z's Avatar
MySunset350Z
i would stay away from zex all together imo.
Old Mar 27, 2008 | 10:15 PM
GolfinZ's Avatar
GolfinZ
Zex is fine, you just need a wet kit. But if your selling the dry kit go with either nx or dynotune.
Old Mar 28, 2008 | 11:19 AM
tnk210's Avatar
tnk210
If I go dynotune what should my shopping list be? I'm starting to get confused
The kit obviously
Dynotune Tps or the window switch?
Spark plugs
What else?
Old Mar 28, 2008 | 11:40 AM
drap660's Avatar
drap660
Get an NX kit and a u-tec (that already has a window switch built in) and be done with it. Besides max u can spray without retarding timing is a 75 shot. Either add a fuel solenoid, fogger, an extra relay and some n20 (fuel lines) or get a new kit. But either way, use a utec to achieve maximum results
Old Mar 28, 2008 | 12:36 PM
tnk210's Avatar
tnk210
I have the Cobb reflash so I'm not switching to utec. I can retard the timing up to two degrees with Cobb.
Old Mar 28, 2008 | 03:20 PM
GolfinZ's Avatar
GolfinZ
Thats safe for up to a 100 shot.
Well...if you want a COMPLETE dynotune kit, you need, and you happen to have a pm :
remote opener
bottle heater
fuel tap
digital psi gauge
kit
tps/window switch
switch center
blow down tube
Old Mar 30, 2008 | 08:09 PM
MySunset350Z
i dont know how other system work, but you dont have to retard timing with the nx kit for a 100 shot or less. i've been running my nx kit on my z for 4 years now without any ecu work. ive sprayed as much as a 150 shot, but mostly i stick to the 100 to 125 shot range. all done without having to retard timing or any major engine work other then 2 step colder plugs. i dont even have a utec.
but make sure you invest in some basics though like a heater, gauges (atleast nitrous pressure and a wideband a/f gauge), fuel shut off, blow down, purge, and an opener if your lazy like me.
everything else you need like a wot switch, relays and a fuel tap should be included in your basic kit. if you dont want to cut your fuel line, theres even a part you can buy for that, but i forget what it was called. i just cut mine.
you really dont need all the controllers and other uber expensive parts unless you plan on spraying at every red light and want to break the 11's on just nitrous. but if thats the case, you might want to look into building your bottom end first.
do a search, a lot of people had issues with zex in the past for various reasons. i wouldnt feel right installing a used nitrous system on my car. you dont know what kind of abuse its been threw and how well kept it was. dont go cheap with nitrous, you will pay a lot more in the long run. but you still dont need a utec...lol
Old Apr 1, 2008 | 04:37 PM
tnk210's Avatar
tnk210
Whats the normal fuel shut-off people get? I was a but confused. I'll have the dynotune window switch and was looking at their a/f lean switch? Do those work together?
Old Apr 1, 2008 | 05:21 PM
GolfinZ's Avatar
GolfinZ
The window switch and lean switch would work together. The lean switch just reads on 02 sensor then will cut the n20 if it gets too lean
Old Apr 2, 2008 | 10:25 AM
tnk210's Avatar
tnk210
I was looking at the fuel pressure switch, there is a 35psi and 45psi both adjustable, which would be preferred for the stock 51psi?
Old Apr 3, 2008 | 01:51 PM
tnk210's Avatar
tnk210
Bump for fuel pressure switch question.
Uriyo_
Sep 8, 2021 08:46 AM
Justin100
Nov 29, 2015 03:58 PM
