Nitrous Oxide Too soon, jr.
VQ35HR 2007 350z Zex Nitrous Kit Install Started
Old Dec 31, 2008 | 04:16 PM
powermark's Avatar
powermark
Default VQ35HR 2007 350z Zex Nitrous Kit Install Started
I am filming and working on the car, so it is going slower then it should. If I could work straight through on this kit, it would take about 5-6 hours to completely do.
Today I installed everything under the engine bay, including part of my purge kit, as well as new intakes. What is left is wiring, finish the purge, and mount the bottle. I will finish it up next week. Here are some of my initial shots
I will be putting together an install video, including dyno runs after it is completed, so stay tuned
You cannot remove the line off the regulator on 350zs. If you follow it to the bottom corner, you will see a quick disconnect. That and the blue clip is removed and transferred to the fitting that comes with the zex kit, as well as a new quick disconnect that goes on the other side of the adaptor to your fuel line.
Nozzles are mounted underneath the pipe about 2 inches past the MAF
The nitrous and fuel are T-ed for the twin intakes, behind the intake manifold and infront of the Zex box. The box is also mounted upside down so I could run the lines better.
It isnt cleaned up yet since I still have work to do.
Old Dec 31, 2008 | 07:20 PM
denchan350gt's Avatar
denchan350gt
looks stealth from the engine bay pic you can't even tell. Nice
Old Jan 2, 2009 | 10:39 AM
kelsey_kaye's Avatar
kelsey_kaye
Wow, please don't quote all the pics.
OP, thanks for the video install. Your work looks good so far.
Old Jan 5, 2009 | 09:39 AM
The Guy's Avatar
The Guy
Nice job. Looking forward to see how it runs.
Old Jan 5, 2009 | 10:20 AM
folgrz's Avatar
folgrz
yes finally
Old Jan 12, 2009 | 07:01 AM
The Guy's Avatar
The Guy
Any updates?
Old Jan 12, 2009 | 08:25 AM
powermark's Avatar
powermark
Been slammed out of my mind, hope to have running in the next 2-3 weeks.
Old May 1, 2014 | 11:28 PM
2007base350z's Avatar
2007base350z
Pleases could someone please explain the factory "quick fuel disconnect" I'm trying to get everything figured out and located before I start my tear down
Juztin
Nov 22, 2015 07:03 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Upstreammiami
Sep 17, 2015 02:45 AM
issyz
Sep 12, 2015 04:18 PM
