Nitrous Oxide Too soon, jr.
which RPM window switch to get
Old Jan 4, 2012 | 08:52 PM
dorrifto's Avatar
dorrifto
Default which RPM window switch to get
I want to get a window switch. It's probably a great safety feature to have.
Obviously I dont want to spend a whole bunch, so I think its between these two:
http://www.zex.com/zx/nitrous-add-on...ow-switch.html
http://www.nitrousexpress.com/produc...ils.php?id=640
Or if anyone else knows of a better option? Or even has one to sell me for way cheaper, that'd be great.
Old Jan 4, 2012 | 09:34 PM
dorrifto's Avatar
dorrifto
also found this BA device that is a window switch, progressive controller, 1st gear delete (idk how that works on a 6mt) and also a tps switch...
Old Jan 6, 2012 | 09:17 AM
BakaN20's Avatar
BakaN20
HSW microedge or dynotune. The microedge can do more than those two controllers you posted for cheaper.
Old Jan 6, 2012 | 03:19 PM
dorrifto's Avatar
dorrifto
where do you see it being cheaper? $400 is the cheapest I have found it. If i am going to spend over $200, I will most likely get the FJO nitrous controller
http://www.jacsport.com/FJO_products.htm
Old Jan 8, 2012 | 08:07 PM
cvc35's Avatar
cvc35
I have the Zex one and love it. The 1st heat lock out on it is pretty simple actually.
Old Jan 8, 2012 | 08:08 PM
cvc35's Avatar
cvc35
1sr gear lockout*
Old Jan 9, 2012 | 02:17 PM
BakaN20's Avatar
BakaN20
My bad, i didn't realize they jacked up the price that much, i haven't been searching for parts in awhile. It used to go for $129 brand new.
The dynotune is still a very good nitrous controller though.
edit:
Here it is for $200
http://www.ws6project.com/user_stor/...1783ce8951b919
Old Jan 10, 2012 | 10:06 PM
dorrifto's Avatar
dorrifto
How do you set a lock out with the 6mt?
Old Jan 29, 2012 | 08:20 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
How the gear lock outs work:
The "first gear" that's locked out isn't actually 1st gear of your transmission. The "first gear," as used by gear lock out systems, means the very first gear you started spraying in. So, if you began spraying in 2nd gear, that will be the "first gear," 3rd will be second gear, and so on. If you lock out first two gears and you begin spraying in 3rd, then 3rd and 4th will not see spray but 5th and subsequent gears will.
For what it's worth, I've had the Dynotune's TPS/window switch for years and haven't had problems. I rarely spray now, though, so I can't really comment on longevity after 3-4 years of use.
Justin100
Nov 29, 2015 03:58 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
AP350z223
Sep 8, 2015 04:38 PM
