Nitrous Oxide Too soon, jr.
New Nitrous Build
Old Jan 21, 2012 | 01:16 PM
NeverBoneStock's Avatar
NeverBoneStock
Default New Nitrous Build
Finally got around to starting this.. Here is the thread on 370 Z Forum....
http://www.*******.com/forced-induct...ous-build.html
Old Jan 21, 2012 | 01:17 PM
NeverBoneStock
Or Maybe Not !!!!!!!!!!!!!
Old Jan 21, 2012 | 01:19 PM
NeverBoneStock
Here is another thread I started on My G37 ....
http://www.myg37.com/forums/engine-d...s-finally.html
Old Jan 21, 2012 | 09:17 PM
NeverBoneStock
Wow .... Over 300 views and not one comment ....
Old Jan 21, 2012 | 10:25 PM
TurboTom's Avatar
TurboTom
What do u want us to say?
Old Jan 22, 2012 | 03:15 PM
NeverBoneStock
Here is how everything will look once mounted ... Now I have the fun task of mounting the N20 and Meth nozzles.. The Takeda intake does not have a lot of room between the throttle body and maf sensor.. Plus I will be keepint the strut bar just to make it more difficult.. Wish me luck ..
Attached Thumbnails New Nitrous Build-img_1984.jpg   New Nitrous Build-img_1982.jpg   New Nitrous Build-img_1983.jpg   New Nitrous Build-img_1985.jpg   New Nitrous Build-img_1981.jpg
Old Jan 22, 2012 | 03:16 PM
NeverBoneStock
Default Pics
More ....
Attached Thumbnails New Nitrous Build-img_1978.jpg   New Nitrous Build-img_1979.jpg   New Nitrous Build-img_1980.jpg
Old Jan 29, 2012 | 12:09 PM
jomamahama's Avatar
jomamahama
about how much dynamat did you order when installing your speakers? Did it reduce road noise?
Old Jan 29, 2012 | 04:05 PM
2bad240's Avatar
2bad240
what are your power goals? and what are you shooting for in the 1/4?
Old Jan 29, 2012 | 08:33 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I'm liking the dual bottle + dual NANO set up a lot! I hope you're planning on making lots of passes at the drag strip.. and hopefully some mid-11 sec runs at minimum.
Old Jan 29, 2012 | 08:52 PM
dorrifto's Avatar
dorrifto
dont you think that n2o and meth is too much **** being sprayed into your intake? not much room left for actual air...
Old Jan 29, 2012 | 09:13 PM
NeverBoneStock
Not really ... The meth is so I can run more N20 safely and this set up has been done many times ... Wish me luck !!
Old Jan 29, 2012 | 09:16 PM
NeverBoneStock
Default Nozzle Success
So I trimmed my intake coupler to make more room and mounted the Meth nozzles on top and the N20 nozzles on bottom .. This was not so bad and also had my A/F bung welded to my new and revised driver side ART pipe.. Next task is Solenoid placement and the fun task of wiring ...
Attached Thumbnails New Nitrous Build-img_1988.jpg   New Nitrous Build-img_1992.jpg   New Nitrous Build-img_1990.jpg   New Nitrous Build-img_1991.jpg
Old Jan 29, 2012 | 09:19 PM
NeverBoneStock
Default More pics...
Here you go ...
Old Jan 29, 2012 | 09:58 PM
NeverBoneStock
I am going to be tuned for a 150 shot ... Quarter mile ???? I haven't given it much thought ...
Old Feb 4, 2012 | 12:48 PM
NeverBoneStock
Default Update....
So every G and Z I see that has Nitrous seems likr they go for the stealth install ... Not me .. I mounted the Fuel , N20 and the heavy a$$ DynoTune Purge Solenoid in the front ... Looks good... Also the Chitty NX sticker came off my N20 solenoid... Pics..
Attached Thumbnails New Nitrous Build-img_2009.jpg   New Nitrous Build-img_2010.jpg   New Nitrous Build-img_2011.jpg   New Nitrous Build-img_2012.jpg   New Nitrous Build-img_2013.jpg
Old Mar 1, 2012 | 05:44 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
I love it. I'm doing a Nano setup on the replacement Z that I just got and was thinking about the same dual setup. I have to admit that I cursed you when I saw that you beat me to it! Where did you run your lines?
I'm hoping to do an LS swap in the next year and figured that the Nano setup would be something to play with right now and wouldn't be wasted money after the heart transplant.
Old Apr 22, 2012 | 12:09 PM
juicinjake's Avatar
juicinjake
i looked at this again today and had a question for you. why the nano and the bottle heaters? is the ambient temp where you are at low typically?
Old Apr 23, 2012 | 07:37 PM
NeverBoneStock
The bottle heaters is for when I run out of Nano ... Not sure how fast everything will go and just want back up ..
Old Apr 24, 2012 | 08:38 PM
BakaN20's Avatar
BakaN20
Very impressive! Thumbs up to your setup. I should have posted my nano kit for sale, then you could have bought it from me, lol.
The NANO is bottle weight specific you get a 10lb nano kit for a 10lb nitrous bottle, etc, etc. But I guess it is easier to fill up on nitrous than on HPA. The track will probably have nitrous, but will most likely not have HPA.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
