Nitrous Oxide Too soon, jr.
350z nitrous question help..
Old Aug 21, 2012 | 04:42 PM
Cubano4ever's Avatar
Cubano4ever
Default 350z nitrous question help..
My car was tune with 100 shot i took car back to the shop to install a walbro fuel pump they said they retune the car with 100 shot and new pump so it dont run rich ... Them i tell them to put shot up to 125 shot and they told me that they already decrease more timing cus of the fuel pump ... They told me that my tune is good for 125 shot and 150 shot .. That i just have to change the jets....
Should i believe it?????? A 100 shot tune with walbro fuel pump can be good for 125 shot and 150 shot???
Old Aug 21, 2012 | 05:08 PM
CLyons0203's Avatar
CLyons0203
Originally Posted by Cubano4ever
My car was tune with 100 shot i took car back to the shop to install a walbro fuel pump they said they retune the car with 100 shot and new pump so it dont run richDid the fuel pump raise the fuel pressure? if not, no need for a retune ... Them i tell them to put shot up to 125 shot and they told me that they already decrease more timing cus of the fuel pump Why are they decreasing timing because of a fuel pump?... They told me that my tune is good for 125 shot and 150 shot .. That depends on how much timing they took out.That i just have to change the jets....
dont forget to get colder plugs
Old Aug 21, 2012 | 06:01 PM
Cubano4ever
I dont know why they told me that i can put 125 and 150 shot with a 100 shot tune ... I dunno how much timing they take out ... They tune my car at hp logic florida ... Jack tune it .. He told me the same ... I dont want to put shot up like they said and blow my engine ... What should i do to put shot up ... Looks like hp logic is the only shop around my house that tune uprev ... I have no more option what should i do .. I live in florida
Old Aug 21, 2012 | 06:52 PM
rtiid22's Avatar
rtiid22
I wouldn't have been satisfied with that answer either.. lol wtf!
I say, put the bigger jets on and go back to them and tell them you wanna strap it on the dyno to make sure the afr is good and there's no knock.
Old Aug 21, 2012 | 07:02 PM
Cubano4ever
They put my the biggers jets and they did not tune it or put it on dyno .. They just said it was ok with the tune it has wtf thats why i will never go back to HP LOGIC i need another place to get a uprev tune...
Old Aug 21, 2012 | 07:58 PM
Italianjoe1's Avatar
Italianjoe1
The HR Z's are pretty stable on nitrous, the wideband setup these cars have from factory means it will hit the same a/f it's targeting.
Nitrous in itself will not change A/F if the jetting is correct, as you are adding more air and fuel at the same time.
Timing, they probably pulled 5-6 degrees to be safe so they don't have to be liable for you blowing the car up with thier tune, so sure you can put the 150 jets in and try it.
I didn't have to adjust anything in my tune when I went from 100 to 125. It made more of a difference when I change from stock cats to test pipes than the extra nitrous, as far as the tuning is concerned.
I'm also not having any issues with fuel pressure, why did you change your pump?
Old Aug 21, 2012 | 10:59 PM
striker27's Avatar
striker27
Why would you need a retune if you just installed a bigger in tank pump??
I do not understand that....
Old Aug 22, 2012 | 06:12 AM
Cubano4ever
They said my car was rich after pump installation i think they just charge me the money without retuning it i was at home and they call me when it was rdy i dont have a way to check if they do retune it
_koubie_
Sep 20, 2015 06:34 PM
NYGiants0186
Sep 8, 2015 10:37 AM
