Nitrous Oxide Too soon, jr.
NOS Fuel Tap
Old Jul 2, 2004 | 01:20 PM
LaPuLaPu's Avatar
LaPuLaPu
Question NOS Fuel Tap
I had a shop install my NOS 75 shot wetkit and the car is running like a champ on steroids. But I do have one concern about how the fuel was tapped. According to the owner’s manual, it states to tap fuel from the fuel rail, but some of Zs with nitrous are using the SPX adapter to tap before the fuel regulator. Without a dyno or wideband, I don’t know if the fuel solenoid is receiving enough fuel due to it being regulated by the fuel regulator, oppose to tapping before the regulator. Would like some input from you gurus, thanks.
Old Jul 7, 2004 | 02:23 PM
LaPuLaPu's Avatar
LaPuLaPu
Reason to why you should tap from the fuel rail:
I was told that the line pressure from the pump is not well-regulated, therefore it may fluctuate (45psi - 51 psi - 47 psi, etc.) whereas the damper provides a constant pressure to the fuel rails.
Old Jul 8, 2004 | 01:44 PM
DriftinZ's Avatar
DriftinZ
I'm having trouble finding where i should tap into my fuel for the silienoid(however you spell it), could someone please help me and tell me where the safest place to tap into. What parts/fittings i'd need to do this. Thanks Alot!
Old Jul 11, 2004 | 01:15 PM
DriftinZ's Avatar
DriftinZ
help........
Old Jul 11, 2004 | 02:02 PM
teh215's Avatar
teh215
I am using the SPX fuel tap to run my fuel pressure gauge and I can tell you it is rock solid at about 51 PSI. BTW, the pressure regualtor is in the tank as part of the fuel pump assembly.
Old Jul 11, 2004 | 03:15 PM
DriftinZ's Avatar
DriftinZ
where do you get this spx fuel tap!?!?! thanks!
Old Jul 11, 2004 | 06:41 PM
DriftinZ's Avatar
DriftinZ
help......thats the missing link to the completion... Or anyone else have a way to tap into the fuel? HELP
Old Jul 12, 2004 | 01:57 PM
teh215's Avatar
teh215
I got mine from a forum member but you can get it directly from http://www.spxkentmoore.com/
Old Jul 12, 2004 | 03:47 PM
DriftinZ's Avatar
DriftinZ
Ummm....interesting website? Do I email them asking about the adaptor?
Old Jul 13, 2004 | 02:05 PM
teh215's Avatar
teh215
SPX Kent-Moore can be reached at 800 345-2233; the adapter costs about $30.00 shipped, part # J44321-4 (quick disconnect something or other)
Old Jul 13, 2004 | 07:28 PM
DriftinZ's Avatar
DriftinZ
Thanks! I'll be calling them tomorrow! I'll keep you posted
Old Jul 13, 2004 | 10:51 PM
jake-trackpack's Avatar
jake-trackpack
Did you have to back off your timming when you put 75 shot? If so how did you do that ???
Old Jul 14, 2004 | 09:39 AM
jake-trackpack
Also do you have any good pictures that i can see as to where exactly you tap into the fuel on the Z please???
Old Jul 14, 2004 | 01:58 PM
teh215's Avatar
teh215
Here is the SPX tap installed. It is the aluminum piece that have the pressure sender threaded into it.
Old Jul 14, 2004 | 04:06 PM
jake-trackpack
thank you
Old Jul 14, 2004 | 04:19 PM
DriftinZ's Avatar
DriftinZ
RRRrrrrr...back up lol. I need to tap into the fuel line to get fuel to my fuel silinoid. You have wires coming off that. HELP LOL So confused.
Old Jul 15, 2004 | 01:21 AM
teh215's Avatar
teh215
x2 Posted
teh215's Avatar
teh215
If course there are wires coming out of it since it is the sending unit for the fuel pressure gauge. The SPX fuel tap simply provides a 1/4" NPT port you can thread whatever you would like into. In your case you would thread in a fuel line.
Old Jul 15, 2004 | 09:41 PM
cyberz350's Avatar
cyberz350
Yours will look like mine
Old Jul 16, 2004 | 03:10 PM
DriftinZ's Avatar
DriftinZ
i'm in love, i need that so bad. So call Kentmoore and tell them what i have and order it?
