North America United States, Canada, Puerto Rico, Mexico
350z overheating
Old Aug 5, 2019 | 01:29 PM
Imports only's Avatar
Imports only
Default 350z overheating
2004 Nissan 350z, 3.5L V6. Overheating, replaced thermostat, all hoses, still overheating, when sitting at a stoplight and the needle starts to climb, if I put it in neutral and give gas the needle goes down to normal...? Ideas on this?
Old Aug 5, 2019 | 01:56 PM
Imports only
Removed fan, and radiator. Checking both. Going to try to direct wire fans to see if they work. Trying to do everything I can before messing with the water pump. I can fix all including that, but will probably have a garage do the pump
Old Aug 5, 2019 | 02:09 PM
Imports only
Heat working, a/c works, water pump working. Only overheating when stopped in traffic for several minutes. Driving is fine, short or long term.
Old Aug 5, 2019 | 02:56 PM
masterjr33's Avatar
masterjr33
good luck man. let me know.
Mine is overheating as well.
i removed the thermo stat thinking it was sticking with a cold lower hose..
still doing it.
Old Aug 5, 2019 | 11:59 PM
813_350Z's Avatar
813_350Z
Did you do a complete and proper bleed on the system after you removed all of those components? The cooling system on the Z is a ***** to get all of the air out of. I will see if I can find the procedures for it for you.
Old Aug 6, 2019 | 12:12 AM
813_350Z's Avatar
813_350Z
06Roadster
May 21, 2014 06:39 PM
Divine
Mar 2, 2014 07:56 AM
FairladyCT
May 2, 2013 12:47 PM
Jamielue
Mar 12, 2013 09:58 AM
HoomanR
Nov 28, 2010 08:23 AM
