wheel alignment shop
Old May 9, 2007 | 05:27 AM
anubyss's Avatar
anubyss
Default wheel alignment shop
My front camber and rear toe is off a bit. Is there a shop that will work on dropped cars with after-market camber/toe kits in the North Jersey area? Some place your would trust your own Z with ? I think there are couple shops in NY but I didn't want to have to drive into NY if I could help it.
Old May 9, 2007 | 05:47 AM
tonester1011's Avatar
tonester1011
CF God
im not sure if its close to u but on rt 27 in edison...freedman tire. they did mine after i dropped it
Old May 9, 2007 | 06:05 AM
Nihilation's Avatar
Nihilation
Nonsense, there's no such thing as too much front camber! Ok, maybe there is, but you'll never get that point without adjustable control arms. Just fix the toe.
Old May 9, 2007 | 06:06 AM
anubyss's Avatar
anubyss
I had work done at a reputable shop in NY but I don't think they knew how to adjust the after-market camber and toe kit. My rear toe is visibly off. My front tires are starting to show inner tire wear. Perhaps I can swing by Edison if I have to head down to MRC for another tuning session. Do they install tires as well?
Old May 9, 2007 | 06:16 AM
tranceformer95's Avatar
tranceformer95
I bought my tires from them and they installed 'em on my nismo's. MRC recommended Freedman Auto and they happen to be 2 mins from my house. It was a no-brainer.
Old May 9, 2007 | 06:38 AM
anubyss's Avatar
anubyss
Sounds good. My front tires should be here today so hopefully I can have an alignment done soon. Too many things to do to the car this weekend lol.
Old May 9, 2007 | 07:33 AM
anubyss's Avatar
anubyss
I'll just post some pics here so I don't have too many people looking at the pics.
Engine bay before.
Engine bay now.
Seeing this does make it look better though.
Too bad the license plate will cover most of this.
So cluttered.
Pulling the wires through those rubber pieces sucked.
I still have to figure out how to mount this thing.
Running a bit lean up top after the 3.12 pulley went in, so the AAM basic fuel return system will go in this weekend (can't raise the fuel pressure right now even after the TN fuel pump mod). Then I'll have to figure out if I need to upgrade the 440cc injectors. I still need to mount the Utec/ecu and run all the wires for the Utec and Zeitronix to be accessible before putting all the body panels back . I hope I don't need another tune! Then I can think about getting my wheels aligned.
Old Apr 1, 2008 | 06:10 PM
dragon11689's Avatar
dragon11689
Freedman Tire -----> You got to remove your front bumper first if your low. They dont accomodate very low cars unless you do that. I spoke to one of the guys there though and they seem really knowledgable.
Old Apr 1, 2008 | 07:08 PM
mifastZ's Avatar
mifastZ
R/T TUNING in Lansdale, PA. They specialize in aligning dropped cars.
www.rttuning.com
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
