Sound bit/Custom Exhaust System
You will need to go to Clear Images Website. They have just loaded it up. Once the site loads up the sound tape will play. Welcome your comments.
Mel
http://www.clearimageautomotive.com/350Z.htm
Mel
Just the headers and exhaust. I did mount some new wheels & tires, Volk LE37, 19" 245f & 275r with Toyo T1-S. The dyno numbers are lower than what others have obtain when you compare stock to stock. My problems most likely is that I made my initial run in fourth gear while everone else is using fifth. It should have been fifth gear but neither I or the tech. knew at the time what the 1:1 gear was in the 350. So when I went back to do the mod dyno runs, I used fourth gear also. Thus the lower numbers but I believe the difference between the runs are true. Soon I'll be doing another some more dyno runs and when I do that one, I'll do some runs in fourth and then fifth. Though the install was not to challenging, I'm not about to start over again. I'm happy with the performance.
Justin100
Nov 29, 2015 03:58 PM
