busy audio install weekend! *whew*
Well, finally tackled the re-install of my audio system. It started out with an amp upgrade, and after three months of collecting more parts, it turned into just about an entire new system!
Head Unit: Alpine CDA-9833 (already installed)
Alpine iPod Adaptor + 20GB iPod (new install)
4AWG Power / Ground Wire + distro blocks (new install)
custom "amp rack" in space behind drivers seat (new install)
mounted Alpine MRV-F340 (front stage) & MRV-T320 (sub amp)
JL Audio 10w3 in under strut tower box (already installed)
It was a fun install...
Wow, looks great, Dan. The amp rack is pretty dope!~ Ya baller!
BTW, I have a question about my head unit.. it recently starts freaking out and the screen scrambles. It won't let me change the track on the CD or anything when this happens. Just curious if you have any ideas why? It goes back to normal when I turn the car off and then back on. *shrug*
I'll see if there is anything to be done about cleaning the interface contacts between the faceplate and the head unit ... maybe a little alcohol swab or something might help clean up the connection.
Originally Posted by neur0sis
Hrm... I have seen this happen to other radios before, and it usually has something to do with the faceplate being loose. Do you take the faceplate on and off a lot? You might try just releasing the faceplate, and making sure it clicks fully in place. I never had any issues with it while installed in my car, though I didn't take the faceplate off much.
Nice setup Dan!!
Nice setup man. Quick question though... of the two dist blocks in that pic, one is fused, right? Bc I'm looking at a similar setup and thought the in-line fuse holder near the battery would be all the fuse protection I needed. Is this other block fused to protect the head unit or something?
Sort of like, being extra careful.
Originally Posted by SPRacing
it looks really good. thats how i would like my set up to be. Did you do it yourself?
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
I'm going to get you on the 9th!
