Another WED Night Drag @Infineon 8/31 Confirmed with Raceway
Old Aug 25, 2005 | 09:15 AM
  #41
fowlman01's Avatar
fowlman01
Originally Posted by JoshTreeFity
Damn what did you guys do to your Zs? Has he lightened it up more or something? I know sac is a faster track but running 13s at infineon is way impressive from a basically stock car.
Sean even has his seat back in.......I think he has a bottle back where the spare used to be and is spraying a little when we aren't looking.
Actually he just has exhaust and JWT intake, street slicks and ice packs and that is about it.
Old Aug 25, 2005 | 10:06 AM
  #42
JoshTreeFity's Avatar
JoshTreeFity
o0o0o0o0o0o street slicks thats all you had to say! I wanna go back out pretty bad but school started back up so my schedule is back to insanity! haha
Old Aug 25, 2005 | 11:00 AM
  #43
corsair's Avatar
corsair
Yeah I can't believe I took 1st place but it was a good feeling. I was up against a Suby WRX STI. Here is my timeslip for my best run of the night.
Dial-In: 13.70
Reaction: .081
I1: 2.068
I2: 5.788
I3: 8.852
I4: 11.485
E.T. 13.707
MPH: 102.017
Attached Thumbnails Another WED Night Drag @Infineon 8/31 Confirmed with Raceway-timeslip.gif
Old Aug 25, 2005 | 01:05 PM
  #44
MATTRESS MAN's Avatar
MATTRESS MAN
Dang, I knew I should've gone last night! Congrats on the best times I've seen a Z run out at Sac. As a matter of fact I've never seen a Z run 13's out there (except a tt). What tires are you running?
JP
Old Aug 25, 2005 | 01:43 PM
  #45
fowlman01's Avatar
fowlman01
[QUOTE=corsair]Yeah I can't believe I took 1st place but it was a good feeling. I was up against a Suby WRX STI. Here is my timeslip for my best run of the night.[QUOTE/]
Looks like you were racing the Tercel! 19.XX sec dial in.
You both hit your dial ins. Great job Sean.
Old Aug 25, 2005 | 03:37 PM
  #46
corsair's Avatar
corsair
[QUOTE=fowlman01]
Actually it was a FORD PINTO!!! It felt like deja vu when I saw the number 19 again. He was damn close to his dial in too! I just barely ousted him.
Old Aug 25, 2005 | 05:33 PM
  #47
fowlman01's Avatar
fowlman01
[QUOTE=corsair][QUOTE=fowlman01]
Now don't put down ford Pinto's, I had one. See Pics.
It must of been a good race with both of your so close to your dial ins. It had to have had the British 1600cc engine in it to go that slow.
Attached Thumbnails Another WED Night Drag @Infineon 8/31 Confirmed with Raceway-65pinto71.jpg   Another WED Night Drag @Infineon 8/31 Confirmed with Raceway-66pinto71.jpg
Old Aug 26, 2005 | 12:23 PM
  #48
MATTRESS MAN
This is a little off topic but since you're drag racers...what do I need to do to my 2004 entusiast 6mt to do a burnout? I've tried pulling the brake light fuse but the brakes still won't allow me to do one. Thanks for your help!
Old Aug 26, 2005 | 12:57 PM
  #49
fowlman01's Avatar
fowlman01
I have never pulled the brake fuse out and I can smoke them like the pic of the Pinto above. Did you try releasing the clutch at higher rpm's? While keeping the brakes on?
Old Aug 26, 2005 | 01:29 PM
  #50
MATTRESS MAN
My process goes... rev to 3.5-4.5k, dump the clutch, moderately press brakes, and before I'm able to keep the tires spinning the brakes (ABS?) stop the tires even though I hardly press them. If at this point I was to apply more gas...bye bye clutch. We did the same thing in my friends 2003 with no problems. In looking at the different fuses, we found that I have no VDC fuse where he does. Also, he has a VDC button where I have a TCS button. I gotta figure this out so I can put my Drag radials to use.
Thanks,
JP
Old Aug 26, 2005 | 01:53 PM
  #51
TunaRollZ's Avatar
TunaRollZ
silly question, but you turned off TCS via the button before attempting the burnout, right?
Old Aug 26, 2005 | 02:24 PM
  #52
fowlman01's Avatar
fowlman01
I was just going to ask that. I don't have VDC, but do have TCS and I turn it off.
Old Aug 26, 2005 | 03:28 PM
  #53
MATTRESS MAN
1st thing I do when I get in my car! I just want to make sure I'm doing everything necessary before I make another attempt. Because if I'm not spinning my tires then I'll be roasting the clutch
Old Aug 26, 2005 | 05:55 PM
  #54
fowlman01's Avatar
fowlman01
I don't know how anybody else does it, but I wait till I feel the back tires go down into the water box. I then proceed to run the rpms up to 6500 rpm's, stay there for awile, not sure how long, but usually when I see some smoke drifting by. I then let off the brake enough to come out of the water pit and spin the tires on the way to the staging lights. Controling the whole thing with the right amount of brake. I have a 5AT, so it is easier for me to do, but I have done that many times with a MT car, just not a 350Z.
Hopefully some of the 6MT guys will post how they do it.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
