Mysterious EMP/dark matter force field on 380?
Old Apr 17, 2011 | 04:40 PM
-Trav-'s Avatar
-Trav-
Default Mysterious EMP/dark matter force field on 380?
So EVERY TIME i take 380, my vdc, slip and ABS lights all turn on. Once I turn the car off it resets and goes back to normal, but otherwise they stay on. It doesnt matter what my speed is or what direction im heading, it never fails. I havent had this happen on any other road thus far. Anyone experience this??
Old Apr 17, 2011 | 04:44 PM
Cali-Darkness's Avatar
Cali-Darkness
Aftermarket wheels?
EDIT: Never mind, just saw your other post saying you have stock wheels...
Old Apr 17, 2011 | 11:13 PM
DivZero's Avatar
DivZero
Does it always come on in the same spot?
Old Apr 18, 2011 | 01:45 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
An EMP would shut your car off...
Old Apr 18, 2011 | 04:18 PM
-Trav-'s Avatar
-Trav-
Thanks for clearing that up. Really, thank you.
Give or take a couple hundred feet. Last time it happened I was going eastbound right before the 101 south ramp, for those who are familiar.
This happens to be right near SFO. So far my only guess is theres some sort of interference involving radio signals or something. Random shot in the dark out of my *** though.
Was kinda hoping to hear something along the lines of "me too"...does anyone even drive by here often?
Old Apr 18, 2011 | 04:56 PM
- bigc -'s Avatar
- bigc -
funny, the same thing has happened to me on the 380, but in my case i wasn't alarmed since i knew i needed to change my brake pads.
check your brake fluid levels as well as your brake pad & rotor thicknesses as those lights generally indicate a brake issue.
Old Apr 18, 2011 | 05:19 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Ah and people was poking fun at him...
Old Apr 18, 2011 | 05:31 PM
-Trav-'s Avatar
-Trav-
Who what people?
Ah i see...I could be due for a pad swap, and I should check the rotors since I dont know if they're still within spec. Thank you for the suggestion.
Still doesnt explain why it only happens there though! Never ever anywhere else, so strange.
Old Apr 22, 2011 | 04:59 PM
- bigc -'s Avatar
- bigc -
funny, it happened to me again today after merging onto 380
Old Apr 22, 2011 | 05:08 PM
Z You Later's Avatar
Z You Later
sounds like a conspiracy! lol, anyone else get the same problems in the same spot?
Old Apr 22, 2011 | 06:49 PM
Zedhead07's Avatar
Zedhead07
Sounds like an excuse to make a road trip just to see if it is a "Zone"!
Old Apr 22, 2011 | 10:54 PM
Flo-ridaZ33
Your welcome
Old Apr 24, 2011 | 08:31 AM
-Trav-'s Avatar
-Trav-
See told you guys! Annoying isn't it?
"Zone"? Please elaborate!
Old Apr 24, 2011 | 09:24 AM
Zedhead07's Avatar
Zedhead07
Ya know, Burmuda Triangle, Twilight Zone, conspirousy therory zone.....Zone brau, Zone!
Some places on this earth have "Zones". Just a pocket of weirdness. It happens.
Old Jul 3, 2011 | 04:39 PM
-Trav-'s Avatar
-Trav-
So I took the middle lane going west instead of the far right lane, and no lights came on...probably will never figure out why this happens, still boggles me mind.
Old Jul 5, 2011 | 09:55 PM
junl350z's Avatar
junl350z
All I can think of is that there is a HOOTERS restaurant in the area... Maybe you stop by there and unboggle your mind...
Old Jul 6, 2011 | 10:26 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I drive 380 every day and never had it happen definitely paranoid now...
Old Jul 7, 2011 | 05:50 AM
Maddawg's Avatar
Maddawg
Question EMP Technologies
Ripely's believe it or not:
latest chp toy is a programable emp generator which can stream bursts of pulse signal at freq. levels which operat the primary operating systems of ecm controlled vehicles. Z systems operate at a freq , which if mapped accordingly, can be controlled from an external source , such as these devices can do. Best alternative is to wrap your modules in lead.
USAF has a EMP targeting model neatly tucked away in a modified 747 which can knock things out of the sky. Cars OS are at a much lower freq and therefore more controllable.
Primarily used for pursuits where deadly force is the alternate option. Road spikes have a tendency to allow the fast vehicle to traction slip and possibily roll/loose directional control.
A similar model is wired into bait cars and simply turned on via remote in theft stings. You might have seen a lower technology model in the public television show.
All of this is public information under scientific technologies advancement.
High freq. pulse generator guns (naturally NRA sanctioned) have been around for a couple of years but not too public. They have a tendency to short out pace makers and hearing aids on those with them, causing wrecks. Controllable optimum range is 750 yds before signal spans out. It is similar to concept of harmonizing signal path in a light beam as a laser does, tighter the concetration, the more it can do to the receiving target.
Old Jul 7, 2011 | 12:18 PM
- bigc -'s Avatar
- bigc -
my suspicion is that SFO is using some sort of frequency to keep birds out of the area. the ramp from the 101 onto the 380 is directly in the takeoff path of the larger planes (747s, 380s, 777s...international flights mostly). since those planes are much lower to the ground when flying over that area (the smaller planes climb quickly and usually take off heading towards downtown SF), my guess is they are worried about bird strikes. just a thought
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
