Pacific Alaska, Hawaii
Motor Oil
Old May 16, 2010 | 11:11 AM
vdemon311's Avatar
vdemon311
120,000 on my car now... mobil1 was used from 20-80,000. Switched to royal purple at 80,000 and car has been running great. Oil pressure is the best it has been. Just seems that rp doesn't last as long as other synthetics
Old May 17, 2010 | 02:09 AM
SonicZ33's Avatar
SonicZ33
You don't have problems yet but I don't think it's worth the chance. Put it this way cummings put a ban on using royal purple in their engines due to the high wear characteristics. Just because your motor is running it doesn't mean anything. Your bearings can be slowly wearing down. I've seen many engines with bearing failures while using all kinds of oil. Bearing failure doesn't necessarily mean it's the oils fault but I've seen waay too many of them happen to have royal purple in it. Enough where it makes you think.
Old May 25, 2010 | 04:58 PM
nismofreak1208's Avatar
nismofreak1208
hmmm is royal purple is as bad as people say it is, then which oil should be used then? i see the amsoil atm 10w-30 isn't too bad but is it accessible on this island? i run royal purple and change every 2,000-2,500, i never wait till 3,000 for the change, so far i've been using it for 10,000 miles, but with this bearing wear issue i've been hearing about from more than one shop and friends...out of all this oil running around, which is the oil on this island can be bought without wear properties coming into play, i read the graphs, and they all sound and look good, so now the question lies in, which one?
Old May 25, 2010 | 05:48 PM
nismofreak1208
never mind, i'm goin with amsoil 10w-30 ATM fluid
Old May 25, 2010 | 07:40 PM
Elperuano's Avatar
Elperuano
I'm gonna go with castrol synthetic 5w 30. Down here in south Florida can get really hot n I'd prefer the lil extra weight for those real hot days.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
