First Look - KPtechnologies Speed Shift Module
Old Jan 22, 2009 | 05:35 PM
  #181
jtgli's Avatar
jtgli
Well I want one so make some more!
Old Feb 17, 2009 | 11:40 AM
  #182
KPierson's Avatar
KPierson
The circuit boards showed up today so it's only a matter of time until we release the Two Step / Speed Shift for the 350Z / G35. Other cars will follow shortly after that!
Old Apr 21, 2009 | 07:50 PM
  #183
str8dum1's Avatar
str8dum1
I want 2 step. I sent ya a PM
Old May 13, 2009 | 04:24 AM
  #184
KPierson's Avatar
KPierson
This module is NOW available on our website!
We have split it up in to three modules - the No Lift Shift module, the Two Step module, and a module that contains both. The pricing is $79.99 for one feature or $129.99 for both features.
However, until the end of May, 2009, we are offering $20 off the module with BOTH features - so you can get the No Lift Shift AND Two Step for $109.99 (plus shipping). To get the discount use coupon code TSNL-25 when checking out.
For more info or to order check out: http://www.kptechnologies.com/products.php#/21
If anyone has any questions about this please let me know!
Old May 13, 2009 | 10:58 AM
  #185
zmedic16's Avatar
zmedic16
would this work with a base 06 revup? i heard i might need some additional items in order to make this work.?
Old May 13, 2009 | 11:21 AM
  #186
Nexx's Avatar
Nexx
ok, i really want this thing but im afraid to messing with wiring in my car. any advice?
Old May 14, 2009 | 06:42 PM
  #187
KPierson's Avatar
KPierson
Because the unit needs a clutch switch the car must have cruise control in order for it to work properly. If the car doesn't have cruise control you can simply add the switch purchased from a dealership or even a junk yard. On a VW I did recently I installed a hood pin switch from an alarm and it worked just fine - the module just needs to know when the clutch first starts to go down.
Nexx, if you are afraid of messing something up try to find a local stereo or performance shop that can do the work for you. The wiring is pretty straight forward and heavily documented on the web.
Old May 16, 2009 | 11:27 AM
  #188
zmedic16's Avatar
zmedic16
can you tell me what part number i would need? im interested in this unit.
Old May 16, 2009 | 06:37 PM
  #189
KPierson's Avatar
KPierson
I looked on a few sites and couldn't find the switch - you would be best off going to a local dealership that has the exploded diagrams with part numbers on them.
Here it is - no part number thought - http://www.trademotion.com/partlocat...layCatalogid=0
Old May 16, 2009 | 06:46 PM
  #190
KPierson's Avatar
KPierson
Here it is:
2530062J00
This is an alternative:
2530062J0E
Old May 22, 2009 | 04:32 PM
  #191
Boba's Avatar
Boba
Sorry to be off topic but I have a question. I posted on the KP forum a while ago about a custom mod. It's a sound module that will make a "BEEPING" sound when shift indicator light comes on. It's the same as the one in the S2000. I'm not sure what the response for that mod was, so I'd like an update to see if it's possible. Thanks
Old May 23, 2009 | 03:01 PM
  #192
DrJonCK's Avatar
DrJonCK
FWIW here's my response: Are You Kidding?? What kind of a "beep" is going to get your attention when the VQ is screaming at 6500+ revs, when you haven't even noticed the bright yellow LEDs flashing in your face? That better be some BLEEP!
Old Jun 1, 2009 | 04:17 AM
  #193
KPierson's Avatar
KPierson
At the present time we have no plans of adding such a feature to our current "stealth" shift light. We feel the super bright LED would be much easier to see then a beeper would be to hear in a high rev situation.
Old Jun 1, 2009 | 04:18 AM
  #194
KPierson's Avatar
KPierson
The Two Step / Flat Shift modules are back in stock and ready to ship!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
apex locator
Oct 6, 2015 05:58 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
