SP boost activated exhaust cutout
Old Jan 27, 2009 | 10:16 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Originally Posted by rcdash
ATP used to have something like this and discontinued it for some reason. I read on some forums about an issue with them leaking over time. How do you address this issue? I think many of us pick exhaust systems for performance when with a device such as this we might pick one we really like for sound quality, but have the benefit of maximum performance. Kudos...
I personally can't wait to get a true dual quiet set up with cats, from Motordyne. I was anticipating having to manually remove the interchangeable components to achieve the level of performance my set up is capable of, but this is a great option... (if implemented well, hopefully)
EDIT: just saw video - looks well implemented, if somewhat bulky... very fast.
As far as the valve itself leaking over time.... the only thing that can cause that would be a build up of carbon etc . You can just pull the valve off and clean all of the sealing surfaces!! Any part that has dirty exhaust running through it over time will get dirty and may require an occasional cleaning. If you do not feel comfortable doing that yourself you can always send it to us and I will be glad to clean it to new specs for you!!
Old Jan 27, 2009 | 12:28 PM
04LIQUIDSILVER's Avatar
04LIQUIDSILVER
in for 3" setup and videos
Old Jan 27, 2009 | 03:16 PM
SoundPerformance
Sound Performance
Pic of the 4" version:
Old Jan 27, 2009 | 03:18 PM
Jay'Z's Avatar
Jay'Z
Sick!!!
Old Jan 27, 2009 | 05:46 PM
thom000001's Avatar
thom000001
Daddy like
Old Jan 28, 2009 | 07:24 AM
rcdash's Avatar
rcdash
Very nice.
Old Jan 29, 2009 | 05:45 AM
IIQuickSilverII's Avatar
IIQuickSilverII
subscribed (and waiting for larry to get online)
Old Jan 29, 2009 | 05:54 AM
JAM3Z's Avatar
JAM3Z
Phenom
Ok, I'm a little lost. How is this different from the open wastegate dumps I have on my car?
Old Jan 29, 2009 | 06:22 AM
SoundPerformance
Sound Performance
Wastegates are used to control the volume of air entering the turbo to control boost. If the boost is too high, they open and let exhaust bypass the turbo.
Exhaust dumps relieve back pressure in your exhaust system between the turbo and tail pipe. With an exhaust dump open you will make more HP at the same boost level due to less back pressure.
Old Jan 29, 2009 | 07:36 AM
JAM3Z's Avatar
JAM3Z
Phenom
Cool. Thanks for the clarification.
Old Jan 29, 2009 | 01:03 PM
chopperman's Avatar
chopperman
So for a True Dual exhaust system we would need two of these valves?
Old Jan 29, 2009 | 02:24 PM
SoundPerformance
Sound Performance
Well, on any Z you want an X pipe... or something similar and I would just put one valve in the center of the x!
Old Jan 30, 2009 | 01:52 PM
G3po's Avatar
G3po
The site says VES-MAIN-VALVE-UNIT - out of stock again until unknown date due to production delays. But talking to them on the phone it appears that they are no longer producing it.
Looked like a nice piece except the pipe cut into you exhaust flow at 90 degrees which is not great for flow at all.
I have a pair of them and they are V-banded on both sides. You do not need to use the shown T-pipe. I welded the V-bands at angles. They do not leak and are built like Brick s-houses. Bought them 2 years ago. To bad they are not selling them anymore.
Old Jan 30, 2009 | 07:18 PM
nomyth46's Avatar
nomyth46
dude these things are wicked............esp. for the sleeper look.......i'm totally interested in the price for the 3" ones
Old Jan 31, 2009 | 09:58 PM
track1z's Avatar
track1z
I like and have considered 3 inch downpipes with these right after and then a stock exhaust back.
Old Feb 11, 2009 | 09:08 PM
Smoker6's Avatar
Smoker6
I ran into this thread when I failed to find any ATP VES cutouts. I have a mazdaspeed6, so I'm completely in the wrong forums, but I'm definitely interested in a 3" cutout! I'll be keeping an eye out on this thread - hopefully the cutout is available soon.
Old Feb 20, 2009 | 10:12 AM
bcmurphy87's Avatar
bcmurphy87
any update on these im interested in a 3"
Old Feb 26, 2009 | 04:48 AM
  #38
QuadCam's Avatar
QuadCam
can you post a video of the valve in action under normal "boost levels" such as using 12-18 psi of line pressure on your shop air line. How much line pressure was used in that video?
Old Feb 26, 2009 | 05:21 AM
  #39
SoundPerformance
Sound Performance
I am 'supposed' to be receiving the 3" versions of the valves today. If so I will post some pics of it in action at 15 psi!! It still opens very quickly!!
Old Feb 26, 2009 | 09:02 AM
  #40
35Z's Avatar
35Z
What if your x-pipe is located forward of the diff. Would it function as intended having the x-pipe located that far back?
