Shop Builds Temp moving posts for some clean up of this section.
taurran : "Testing new waters" with the Turbonetics ST
Old Oct 8, 2007 | 12:13 PM
  #681
booger's Avatar
booger
Any updates on the car ?
Old Oct 8, 2007 | 12:17 PM
  #682
Julian@MRC's Avatar
Julian@MRC
+1
Updates FTW?
Old Oct 8, 2007 | 07:40 PM
  #683
taurran's Avatar
taurran
+1
Where's the updates?
Old Oct 9, 2007 | 04:12 AM
  #684
Audible Mayhem's Avatar
Audible Mayhem
My350z
We are STILL having issues with the turbo blowing oil out the seals. thats it, if you want to elaborate at all craig , feel free...
Old Oct 9, 2007 | 04:24 AM
  #685
ZU L8R's Avatar
ZU L8R
Viper Sellout
did you try my idea?
Old Oct 9, 2007 | 06:40 AM
  #686
DanielW's Avatar
DanielW
man I know this has got to be getting frustrating craig, but soon you will be driving around in the baddest ST Z in the country!
Old Oct 9, 2007 | 07:41 AM
  #687
MI 35th's Avatar
MI 35th
OGPremierMafia
How did the nitrous jets idea go over Jeremy?
Where is the oil for the turbo coming from?
You could run an larger oil cooler, that would significantly lower pressure in the system and you cold tap the oil feed from that source instead of the engine, this would reduce oil pres and oil temps maybe low enough to stop from killing seals.
I know that I had so many problems with oil on my MR2 that we came up with an oil distribution block. I machined a block of Aluminum with 3 outlet ports and 1 inlet port coming straight from the head. one for oil pressure sensor, 1 port for Oil Pres Gauge and 1 for turbo feed. This allowed time for the oil to slow down in a chamber before being fed into the turbo. I mounted it about 3inches above head as well so at idle there would be even less pressure, Worked out great.
Ill find a pic of it and post her up.
Old Oct 9, 2007 | 08:14 AM
  #688
redline350ZZ's Avatar
redline350ZZ
Don't feel bad Craig I'm stuck on an Island with no tune...
Old Oct 9, 2007 | 09:11 AM
  #689
ZU L8R's Avatar
ZU L8R
Viper Sellout
thing to remeber is that on most of the built motors is that people replace the oil pumps with the revup pumps. That pump flows about 30% more than the reg. This prob. isn't helping the situation but should be done with the built motors. Just gotta figure out a way to keep the pressure down to the turbo.
Old Oct 9, 2007 | 09:26 AM
  #690
taurran's Avatar
taurran
Yep. I was just joking about the updates. I think people get the gist of what we're up against. At this point I think it's a combination of a few things. Nothing is really WRONG with the setup, we just need to find out how to manage the oil feed to the turbo.
I personally don't care if we run a smaller restrictor, as long as my engine has enough oil and it's not burning off or blowing by at the turbo.
Old Oct 9, 2007 | 09:27 AM
  #691
taurran's Avatar
taurran
Damn that's crazy, but a great idea. I'd like to run an oil cooler eventually as well. First things first, though, to get the car tuned and on the street...
Old Oct 9, 2007 | 12:41 PM
  #692
DanielW's Avatar
DanielW
screw the street! get that thang on the track bro
Old Oct 9, 2007 | 12:48 PM
  #693
taurran's Avatar
taurran
Trust me I've been planning on it. heh. Too bad I missed the big drag meet the other week. I'm signed up for the November 24th Tampa Racing drag day so I'll definitely be running it then.
I'm also changing to a 7am-3pm shift at work so I'll be able to run it at drag and/or drift test and tunes at bradenton every week.
Old Oct 9, 2007 | 02:06 PM
  #694
DanielW's Avatar
DanielW
less pressure with not as many people watching you.
Old Oct 11, 2007 | 02:34 PM
  #695
35ounces's Avatar
35ounces
03 CS Track 6MT
Craig/Jeremy,
can you at least tell us which pipes you replaced and how tight it was to fit bigger piping in?
Old Oct 11, 2007 | 02:45 PM
  #696
DanielW's Avatar
DanielW
^my license plate says D's 350Z and this chick at work thought it said D's 35 OZ
Old Oct 11, 2007 | 03:02 PM
  #697
superchargedg's Avatar
superchargedg
Damn Noobs
Good luck with everything but damn i wish i had a 7-3 job.
Old Oct 11, 2007 | 05:12 PM
  #698
taurran's Avatar
taurran
Originally Posted by 35ounces
Craig/Jeremy,
Up pipe/down pipe with a simplified open dump. And yes, it was a very tight fit. For now I'm using some slightly modified stock intake piping (black chrome). I'll eventually be going with a full 3" intercooler/intake tract if we need to open it up some.
Old Oct 11, 2007 | 06:42 PM
  #699
Zilvia's Avatar
Zilvia
do u have a catch can on the car.....maybe that will catch the extra oil leaking out.......
Old Oct 11, 2007 | 08:41 PM
  #700
taurran's Avatar
taurran
Not at the moment. I was considering doing a husky or getting a greddy can. I'd ultimately rather have the issue fixed completely before I try to put a band aid over it.
