Shop Builds Temp moving posts for some clean up of this section.
My "Z33Art" Custom Supercharger Build *PICS*
Old Jan 26, 2008 | 07:58 PM
  #81
Quamen's Avatar
Quamen
I am looking to be done by April. I should say that is when I am looking to fly the person who is going to tune it up here.
I would like to have the car up and running by mid March so I have time to work out any small issues like fuel pressure, oil leaks, coolant leaks or anything else that might pop up.
Just did my taxes today and I will have the money in 10 days so between that and my bonus at work I should be good to go parts wise.
  #82
Quamen's Avatar
Quamen
Anyone have any input on the fan question?
Old Jan 26, 2008 | 08:06 PM
  #83
BornSlippyZ's Avatar
BornSlippyZ
Great work...Subscribing!
Old Jan 28, 2008 | 09:56 PM
  #84
Quamen's Avatar
Quamen
Amsoil Breather Filter
Old Jan 28, 2008 | 10:03 PM
  #85
Quamen's Avatar
Quamen
I was wondering if anyone has ever considered running CO2 or something through the coolant ports on the intake manifold neck where everyone does the coolant bypass?
I was just working on that area of my car and it seemed like an idea. The main problems I could see happening would be that the air would become more dense obviously post-MAF. The other issue I could think of is condensation from the rapid cooling.
Any ideas or input?
Old Jan 29, 2008 | 02:51 PM
  #86
booger's Avatar
booger
Originally Posted by Quamen
This may be a somewhat odd question but lets say that you put a fan on one side of a radiator pulling and another fan on the other side pushing are the CFM's cumulative?
Good question !
With your radiator not sitting up right and in direct air flow it maybe an option . But thinking about it , I would just put one fan on the back side of it [ pulling ] That way you have the whole front of the radiator exposed to fresh air . JMO
Old Jan 29, 2008 | 09:43 PM
  #87
Quamen's Avatar
Quamen
Originally Posted by booger
Good question !
I did some research on HVAC and it would increase the pressure capabilities of the fans and have very little cumulative affect. I am going to put one fan on fan on top on the driver side and one fan on the bottom on the passenger side.
The reason I have chosen this layout is because I have some fairly big fans and they won't fit next to each other on the same side. I did this to get as much coverage as possible though. It also has to do with spacial restraints in a few areas which will be evident in pictures.
Old Jan 30, 2008 | 10:24 AM
  #88
Quamen's Avatar
Quamen
Breather Filter Installed:
Oil Feed/Drain lines to supercharger:
Old Jan 31, 2008 | 07:59 AM
  #89
Quamen's Avatar
Quamen
I finally got all of the dimensions to calculate my impeller speed. With my crank pulley (6.22" which is bigger than stock), a 3.25 supercharger pulley and 6500rpm my impeller will be at 44,784 rpm. I believe that I should be at about 7-8psi then. With my upgrade that is on the way I think I will be at about 10-11psi with the same pulley hopefully.
Old Feb 3, 2008 | 08:56 AM
  #90
Quamen's Avatar
Quamen
Some more Vids I found of PPIHC:
http://youtube.com/watch?v=EnY0-xNtOvs
http://youtube.com/watch?v=FRaQgP0XnDM
http://youtube.com/watch?v=QFgVvAJb5eI
Old Feb 3, 2008 | 09:03 AM
  #91
Jay'Z's Avatar
Jay'Z
How much longer??
Old Feb 3, 2008 | 11:38 AM
  #92
Quamen's Avatar
Quamen
Originally Posted by Jay'Z
How much longer??
lol. Soon hopefully. I'm having trouble getting to the machine shop to finish the radiator mounts.
Old Feb 3, 2008 | 11:42 AM
  #93
Jay'Z's Avatar
Jay'Z
Dammit.. Id give u a ride but im too far..
Old Feb 3, 2008 | 07:28 PM
  #94
Quamen's Avatar
Quamen
Lol. Not driving wise.
My friend with machines has been busy snowmobiling and hasn't been around to let me into the shop.
It will still most likely be April before it is finished. However, I am honestly a day worth of work away from have the coolant system completey finished so I can test it out. I can't really do anything with my supercharger until I get the impeller and volute back.
Old Feb 6, 2008 | 12:49 AM
  #95
Quamen's Avatar
Quamen
Throttle body coolant bypass is done.
Started working on a wire tuck on the passenger side front near the head light. The only wire on that entire loom that I use is the headlight plug. So I am pulling the entire harness apart as far back as possible and moving the plugs elsewhere.
I am also finishing up a number of small little things like getting the fittings for my oil catch can and coolant overflow. Should have a good update at the beginning of next week.
Also have a UTEC and a wideband on the way thanks to Performance Factory!!!
  #96
Quamen's Avatar
Quamen
Deleted because the internet sucks
Old Feb 6, 2008 | 01:48 AM
  #97
Jay'Z's Avatar
Jay'Z
Cool.. Double post though bro..
Old Feb 6, 2008 | 07:49 AM
  #98
Quamen's Avatar
Quamen
My internet was acting up and as far as I now it didn't post lol. Stupid thing just kept saying "posting quick reply".
Old Feb 7, 2008 | 12:45 AM
  #99
Quamen's Avatar
Quamen
It almost 4am and I just got done working on the car for a long time.
I finished my wire tuck on the passenger side. I opened up the entire loom and pulled 7-plugs that were up near the headlight all the way back. Now there is only two plugs on the passenger side just like there is on the driver side.
I got all of my fittings for the supercharger sealed up and tightened also.
I also finished making the bracket for my oil catch can which will be installed this weekend.
I finished up my power steering cooler lines. I have choosen to use the stock oil cooler still as I have yet to encounter boiling. However, I have a really trick mount made for it that will look really clean when welded onto the front brace.
The last thing I got done was mounting my fans to the radiator. Since I went with the largest fans possible I had to trim them a bit to get them to fit. I also tested them and those things flow an amazing amount of air.
Next up this weekend is my boost gauge, A/F gauge if it arrives by Friday, finish installing oil catch can and power steering cooler and then hopefully get some stuff powder coated.
Old Feb 8, 2008 | 09:11 PM
  #100
Quamen's Avatar
Quamen
I am going to weld a tab onto the underside of the brace to support the U-bend side of the power steering cooler.
The posts for the rear radiator mounts are not cut to length but will be adjustable. Still need some more bolts for some of the stuff also.
Fans are mounted and wired. They work great.
I am going to finish up my carbon fiber switch panel tomorrow.
Please note that the mounts are not completely finished for the radiator and will not be so boxy looking when I am done.
