Shop Builds Temp moving posts for some clean up of this section.
Forged Performance: Another 600whp Project hits the road!
Old Apr 3, 2008 | 02:17 PM
  #101
D350Z10's Avatar
D350Z10
Ive searched but can't find a thread where it shows you exactly how to bleed a clutch.. anyone have a write up????
Old Apr 3, 2008 | 03:19 PM
  #102
coachk's Avatar
coachk
DIY...fill up the clutch master cylinder and then open the bleeder until the fluid starts to run out, then close the bleeder valve. go ahead and refill the clutch master cylinder and then have your buddy press the clutch pedal to the floor and open the bleeder real quick and then close it. have your buddy release the pedal then push it back in again and open and close the bleeder screw on the slave cylinder. do that several times and once the air is out, the pedal should feel normal and no air bubbles are coming out of the slave cylinder bleeder screw.When you do this make sure the fluid level in the clutch master cylinder doesn't get to low because air could get stuck in the system.Hope this helps
Old Apr 3, 2008 | 03:23 PM
  #103
D350Z10's Avatar
D350Z10
Thanks Coach!!
Old Apr 6, 2008 | 07:53 AM
  #104
D350Z10's Avatar
D350Z10
Default updates...
Well bleed the clutch yesterday and no fukin luck... there was no air in the cyclinder. The pedal would go down easy but wouldn't come back up.. So now I am gonna swap out the slave cyclinder . Hopefully this will be the answer to the problem. IT was a beautiful weekend, sunny outside and all I was able to do was work on my car.
This has been a terrible experience; lots of money, stress and no running car after 8 months...
Old Apr 6, 2008 | 08:40 AM
  #105
XKR's Avatar
XKR
Dil.....I opened a thread about that...you have to keep doing it. The same thing happened to me. The dealer even changed the master cylinder and the slave and still it did not help. You have to keep bleeding it until you bleed....
Old Apr 6, 2008 | 08:53 AM
  #106
D350Z10's Avatar
D350Z10
^ I bleed the clutch for about a hour... went through half a bottle of fluid... and there was zero improvment....
Secondly the car won't even start now...
Old Apr 6, 2008 | 08:55 AM
  #107
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
how does the pedal feel when you push on it? Just it sort of "spring" downward with very little tension, or does it push downward as you would normally expect it to?
BTW - very nice setup, nice and clean. Love the bumper!
Old Apr 6, 2008 | 09:00 AM
  #108
D350Z10's Avatar
D350Z10
The pedal goes down like normal for the 3/4 of the way... but the last 1/4 I have to push pretty hard in order for the car to engage to start it. And the peddal will not come back up... it takes about 2-3 hours for it to come back up by itself.
Old Apr 6, 2008 | 09:06 AM
  #109
XKR's Avatar
XKR
Dil.....
I went through the samething.....The dealer went throught it also...but I assure you the bleeding will fix it. It also would not start for me. I pulled the pedal up with my hand and kept pumping it...it then would start. I also had problems getting it in gear.
I know how you feel....when you think you got rid of all the air....there is still some left. Keep bleeding ....keep bleeding !!
Now can I get free entry fee for this info.... j/k
Old Apr 6, 2008 | 09:08 AM
  #110
Z1 Performance
Former Sponsor
and the car just cranks but won't fire?
Old Apr 6, 2008 | 09:10 AM
  #111
D350Z10's Avatar
D350Z10
lol... thanks well looks like im gonna keep bleeding it.
So let me get this process clear....
Pump 5-6 times, on the 6th time hold the pedal down, then open the bleeder valve... let the fluid poor out till it stops (2-3 seconds) then wait an additional 2-3 seconds when no fluid is coming out and close the valve, then release the clutch pedal.
Is this correct? This is what I have been doing...
  #112
D350Z10's Avatar
D350Z10
Yes the car cranks bout wont turn over...
Old Apr 6, 2008 | 09:12 AM
  #113
XKR's Avatar
XKR
Here is something else that I went through....Shifting at low speeds..the clutch would feel sticky...but under boost the clutch would feel good. You will soon pass the air throught the system. Bleed Dil.... Bleed
I had to go look it up...but that looks about right.
Old Apr 6, 2008 | 09:22 AM
  #114
D350Z10's Avatar
D350Z10
__________________
Old Apr 6, 2008 | 09:23 AM
  #115
Z1 Performance
Former Sponsor
here is what I've done and it's worked for me - I had a similar problem bleeding mine when we did the new motor/clutch, etc....and I even replaced the master and slave at the same time too (sort of a "while we're in there" thing), and it still gave us a hard time until:
http://www.v8archie.com/arch4.htm
as with anything I am sure there is more than one way to do it successfully. I will be at the shop later, I could cut and paste the factory procedure if you like
for some reason, this car seems insanely hard to bleed anything....don't even get me started on the coolant (took us hours!!!)
Old Apr 6, 2008 | 09:27 AM
  #116
D350Z10's Avatar
D350Z10
Thanks XKR and Z1 SO Much for your help!!! I am gonna go try to bleed this thing now.
  #117
XKR's Avatar
XKR
+1.....
Samething I had to do...change master and slave cylinder and it was still the same....the dealer went through bottles of fluid before it would fix it.
Old Apr 6, 2008 | 09:29 AM
  #118
XKR's Avatar
XKR
We did not say Bleed ...we said Bleeeeeeeeeeeeeeeeeed it Dil
Old Apr 6, 2008 | 09:37 AM
  #119
Z1 Performance
Former Sponsor
edit - gotomypc rocks
http://www.z1auto.com/images/350ZCLU...TSPECSHEET.pdf
Old Apr 6, 2008 | 10:21 AM
  #120
D350Z10's Avatar
D350Z10
Im telling you guys its not air in the system... already went through a 3/4 bottle of fluid ..... still no luck
This time I didnt pump the clutch like the sheet said, I just had my buddy depress the clutch then he held it and I had him pull it back up.. no luck
I think it really is a bad slave cyclinder... *** my life
