Shop Builds Temp moving posts for some clean up of this section.
Sound Performance G35TT race gas dyno (769rwhp)
Old Nov 18, 2009 | 06:48 PM
  #41
thom000001's Avatar
thom000001
Like str8 put up...
just did 540rwhp @ 14psi on 93 octane about 2 months ago (almost 10K on the setup) and gawd knows what the clutch was up too....it died days later lol.
Not bad for stock heads/cams on basically the stage 1 setup
Tom
Originally Posted by GBoger
is there a pump gas dyno for this car?
Old Nov 18, 2009 | 07:46 PM
  #42
str8dum1's Avatar
str8dum1
you always have to add that lil disclaimer.
i remember you saying you have it tuned for race gas and just so-so for pump. Is 14psi all you can run on pump before you start knocking?
Old Nov 19, 2009 | 02:49 PM
  #43
GBoger's Avatar
GBoger
Originally Posted by thom000001
Like str8 put up...
Tom
ninja edit: nevermind...
Old Nov 19, 2009 | 02:59 PM
  #44
str8dum1's Avatar
str8dum1
can you not see the graph? its posted 2 times in this thread. The green line on that graph is teh pump gas hp curve
Old Nov 19, 2009 | 03:14 PM
  #45
Aced16's Avatar
Aced16
Tom i know you stated you are running the SP stage 1 block, any other add ons? (head stud kit, gasket, etc) mind giving us a full break down please
Old Nov 19, 2009 | 04:56 PM
  #46
GBoger's Avatar
GBoger
oh yeah there it is it looks like its fully spooling up closer to 4200 rpms though...
Old Nov 20, 2009 | 07:06 AM
  #47
thom000001's Avatar
thom000001
Str8,
I have had it as high as 18psi, but the plugs showed some signs of light detonation. So I don't like to run it up over 17psi on pump. Larry has it tuned to start adjusting the timing and fuel at anything above 15.5psi....
Will most likely do cams over winter, so I know larry will adjust the tune around more, maybe give me 18psi to use on pump
But 15psi is usually plenty more than for most cars up here
Aced,
I have L19 headstuds, and HKS Headgaskets. (Rest is pauter rods, weisco pistons, ACL bearings, Rev-Up oil pump). Nothing fancy. Still 3.5L
G,
The car spools almost...what 1000rpm faster on the street lol (yes even though the mustang dyno is load bearing). And since this dyno I have swapped out the 3.5FD for a 3.3FD, that brought it down about another 200rpm.
In 1-3rd I get full boost by like 3400-3800rpm'ish.......5,6 - like 2800rpm lol (Thank you stock cams.....but they DIE above 6200rpm pretty bad)
Tom
Old Nov 20, 2009 | 08:13 AM
  #48
Aced16's Avatar
Aced16
thanks for the info tom, much appreciated!
Old Nov 20, 2009 | 10:05 AM
  #49
str8dum1's Avatar
str8dum1
Ah ha, there it is again! LOL
Tom
Could you detect the knock on your EMS or only by looking at the plugs? No meth, correct?
Str8,
Tom
Old Nov 20, 2009 | 10:45 AM
  #50
thom000001's Avatar
thom000001
It was real mild knock. Doubtful the ecu was even registering it. Couldn't feel it while driving (I know what it feels like when its extreme...had a z31t that let go cause of it lol). You could tell on the plugs though (it was actually a little heated debate on if it was knock).....so we error'd on the side of caution and I back it down a touch.
Tom
P.S. - hey I'm consistent lol.
Old Nov 22, 2009 | 12:48 AM
  #51
GT.Z6MT.'s Avatar
GT.Z6MT.
-hey Tom , what bore size are this wiseco Pistons in your block, are they 95.00mm standard, or 96.00 0.020 mm over??
- I'm asking because i'm right now in the process of built mine, and I was thinking on put 95.50 standard or if is going to be better to get it this 0.020 over, to the 96.00mm bore .Thank you
Old Nov 23, 2009 | 02:20 PM
  #52
thawk408's Avatar
thawk408
For the sake of a better fit, do .020 over. I did 95.5 at the time, but had hardly any miles on the block.
Old Feb 22, 2010 | 02:25 PM
  #53
Reid@SP's Avatar
Reid@SP
This things weak sauce!!
Keep an eye out for this bad boy to have new Billet Precision turbos, stronger clutch, and ProEFI Flex Fuel for e85 capabilities!!
Reid
Old Feb 23, 2010 | 07:11 AM
  #54
rrmedicx's Avatar
rrmedicx
Any sneak peak pics of the turbo upgrade/revision?
Old Feb 23, 2010 | 07:28 AM
  #55
Motormouth's Avatar
Motormouth
why does the dyno stop at 6k, or did I miss that?
Old Feb 23, 2010 | 07:29 AM
  #56
rrmedicx's Avatar
rrmedicx
I believe its because he is using stock cams which I'm guessing stop making power after 6K.
Old Feb 23, 2010 | 08:21 AM
  #57
Reid@SP's Avatar
Reid@SP
Stock cams are the answer. We are working that issue out with Tom as well
Reid
Old Feb 26, 2010 | 11:55 AM
  #58
thom000001's Avatar
thom000001
Yup was the stock cams. Power falls like a rock above 6k (actually 6200rpm)...just used this part for display purposes.....
cams going in, in a few weeks. Still cold here, haven't seen my car in 3 months.
Tom
Reid
Old Feb 26, 2010 | 06:57 PM
  #59
Reid@SP's Avatar
Reid@SP
Sure!! Tom's preview:
Billet 5557 or 5857 Twin turbos (still undecided)
Cams (example dyno below with and without cams)
Southbend 6 puck clutch
ProEFI Flex Fuel Sensor (for runnning E85)
Zeitronix Ethanol percentage analyzer in either RED or BLUE display (for ProEFI 48 units)
SP Diff Brace (not sure if he's getting this or not but I hope he is!!)\
aaannnd hopefully one of these!!
Installed on a Supra as an example
Reid
Old Feb 27, 2010 | 01:42 PM
  #60
rrmedicx's Avatar
rrmedicx
Lets hope Thom picks up all that stuff. That would be nice to see the before and after dyno's with the Exhaust dumps. Curious to see how well they perform on a VQ35 with TT's.
