Shop Builds Temp moving posts for some clean up of this section.
Forged Performance: rcdash's Twin Turbo G35
Old Jul 14, 2009 | 07:08 PM
  #81
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
190F...that's terrific.
Did you also relocate the trans temp sensor?
Old Jul 15, 2009 | 06:48 AM
  #82
rcdash's Avatar
rcdash
Yes, I moved the temp sensor to AFTER the cooler. Much more stable temp readings. I was able to re-use one of Chris's custom brackets and tucked and tied hoses - very secure - I think it'll be up to Forged standards!
The highest temp to date in 96 degF ambient conditions, boosting 15 psi and then sitting in stop-and-go traffic, has been 206 degF. I turned the fans up to 100% and it dropped right back to 195.
Old Jul 15, 2009 | 08:13 AM
  #83
str8dum1's Avatar
str8dum1
i guess you are using an aftermarket fan controller?
Old Jul 16, 2009 | 11:00 AM
  #84
Sharif@Forged
Forged Performance
Very nice. I think a blast through the moutain roads is in order.
Old Aug 18, 2009 | 07:52 PM
  #85
rcdash's Avatar
rcdash
Yes, I use this (very nice for aftermarket fans with up to 60 amps of current handling capability):
Soon, I hope.
Old Aug 19, 2009 | 04:04 PM
  #86
GBoger's Avatar
GBoger
why does it say sleeps in a 350z under your name in your avitar?
Old Aug 22, 2009 | 08:40 PM
  #87
rcdash's Avatar
rcdash
Well, I guess the admins think I post here too often. Now that premium memberships cannot be renewed, that's gone for now...
EDIT: The issue with renewal has been fixed! I'm premium once again!
Old Aug 23, 2009 | 03:10 PM
  #88
Cass007's Avatar
Cass007
What?!?!? No more premium members
Old Aug 23, 2009 | 03:43 PM
  #89
03threefiftyz's Avatar
03threefiftyz
+1.....I'm confused...no more premium membership?
Old Aug 31, 2009 | 07:56 PM
  #90
JasonZ-YA's Avatar
JasonZ-YA
The issue is being worked.......
-J
Old Sep 23, 2009 | 08:43 PM
  #91
03threefiftyz
Can someone scan the pics on here.....................I'm cheap . Which cars were featured?
Old Sep 24, 2009 | 04:59 AM
  #92
rcdash's Avatar
rcdash
You caught my ninja edit. Let me see what is allowed...
EDIT: OK, in the next 2 weeks the NOV 2009 issue of Modified Magazine has coverage of ZdayZ and the airstrip run! Lots of good pics. Go grab a copy!
Old Apr 5, 2010 | 07:47 PM
  #93
D-tuned's Avatar
D-tuned
Can you post your current PCV system setup
Old Apr 6, 2010 | 06:35 AM
  #94
rcdash's Avatar
rcdash
Okay, I think these are the two best pics that reflect my current setup. There's no good way to take a pic of the 1/2" hose going to the driver's side rear port, but suffice to say it just goes directly to the catch can and travels to the left of the breather as pictured below.
Here you can see the breather, the 1/2" hose going to the driver's side port on its left and the check valve on the right going to the intake manifold:
Here is the catch can with the t-junction also pictured, that sucks gases both into the intake manifold and driver's side turbo intake.
From the catch can:
- 1 hose goes all the way around to the driver's side valve cover port.
- the other hose goes to a tee
-- one end of the tee is 3/8" in size and goes to the cosworth (check valve allowing air to LEAVE catch can)
-- other end of the tee is 1/2" and goes to the driver's side turbo intake (check valve allowing air to LEAVE catch can)
* I think this would work, perhaps even better, with the driver's side port plumbing and passenger PCV breather reversed, but I haven't had a chance to redo the plumbing and datalog it. The reason I did it this way is that the passenger PCV nipple points up and this prevents oil from dripping out of the breather, but rather drips back down into the valve cover. If you drill open the driver's side valve cover port, then it really doesn't matter which way you plumb it.
I attached a picture modified from someone else's artwork, so the positioning of the components is a little off, but you get the idea. The arrows represent check valves. Please note that when I datalogged crankcase pressure, I was actually measuring pressure in the catch can. This set up limits crankcase pressure to 1 psi under 15 psi of boost and it provides 2-4 psi of vacuum at idle (in my engine).
Attached Thumbnails Forged Performance: rcdash's Twin Turbo G35-catch-20can-20system2.jpg
Old Apr 6, 2010 | 10:03 AM
  #95
D-tuned's Avatar
D-tuned
thanks!! One of your previous PCV set-up you disconnected the line going to the into intake plenum. You stated your reason for doing so was because it was pulling too much vacuum during decel causing the car to smoke. Curious as to why you reconnected the line to the plenum
Old Apr 6, 2010 | 01:48 PM
  #96
rcdash's Avatar
rcdash
I think a better explanation is that crankcase pressure was building and on decel, oil was seeping past the rings to decompress it! I have a much better catch can set up now, so not worried about pulling oil through the manifold (catch can is baffled and stuffed with a sponge!).
Old Apr 6, 2010 | 04:16 PM
  #97
str8dum1's Avatar
str8dum1
seriously, next winter we are going to have to do a wire tuck on your car. That mess it outta control!
Old Apr 6, 2010 | 06:07 PM
  #98
GBoger's Avatar
GBoger
did i read correctly that you're running dual haltechs? how does that work?
Old Apr 6, 2010 | 07:11 PM
  #99
rcdash's Avatar
rcdash
Ummm, no. Not sure where you got that from. str8dum1 has a haltech as do I, but on our respective cars.
Hey, that's nissan's fault. I wish I had more time to make it look nice.
Old Jul 5, 2010 | 05:06 PM
  #100
jmicaelk's Avatar
jmicaelk
Sorry to post on an old thread, but I'm just wondering about you current setup and what power you make right now and how the AT is handling it ??
Regards Micael
