350Z engine strong knocking sound after revving
Old 04-25-2016, 06:08 PM
Misaka_10032
Misaka_10032's Avatar
Default 350Z engine strong knocking sound after revving
Hi, I know I screwed up, but after revving very high after a cold start.
My engine started a strong knocking sound, it almost sounds like something fell off in a cylinder and is knocking the cylinder itself.
Here is a youtube link:
The noise goes up in frequency with rev, the idle rpm is still very stable, but the throttle response seems very very slow, and the car is clearly slower than normal.
Also, I had a grinding 3rd gear, but I do know if transmission is the problem here.
Please give me some thoughts,
Thank you very much!
Old 04-25-2016, 06:14 PM
turboed350z
turboed350z's Avatar
Thrown rod....
What else is new? Young immature 350z owner trashes another car...
Old 04-25-2016, 06:19 PM
Spike100
Spike100's Avatar
That is a very bad sound. Your camshaft is ruined, and your valves are "toast."
You are looking at an engine rebuild or buying a rebuilt engine.
Old 04-25-2016, 07:04 PM
Received 2,305 Likes on 1,660 Posts
Motor is trashed
Old 04-25-2016, 10:23 PM
Justin100
Justin100's Avatar
do a compression test.
report to us the compression readings.
drain the oil and remove the oil pan check for metal shavings.
then go from that information.
its hard to diagnose a car just by sound can be plenty of symptoms dont jump the gun until you get concrete facts.
Old 04-25-2016, 11:08 PM
tcode
tcode's Avatar
That's a rod knock 99.6%.
The following 4 users liked this post by tcode:
Arrtus (04-28-2016), StarkdrivenZ33 (04-26-2016), StuLax18 (04-26-2016), TeamZleep (04-28-2016)
Old 04-26-2016, 01:04 AM
StarkdrivenZ33
StarkdrivenZ33's Avatar
@Tcode I just cried laughing haha... ugh that was great.
@misaka "after revving very high after a cold start." this is like saying "after having sex with that prostitute I got aids." cold starting a car and reving it up is begging to throw something.
tcode (04-26-2016)
Old 04-26-2016, 01:41 AM
dcains
dcains's Avatar
100% rod knock from spun bearing.
Old 04-26-2016, 03:17 AM
Received 9,099 Likes on 6,556 Posts
for a dead motor
Old 04-26-2016, 05:28 PM
Toneloc
Toneloc's Avatar
So you high revved your car cold, how bout somebody shakes you from a deep sleep then you run a marathon. Doesnt sound like that would be fair way to treat you does it?
Old 04-26-2016, 06:18 PM
Its not cold unless your car tells you it's cold... Thats going to be an expensive mistake though... Can only do that with rental cars or something still under warranty.
Old 04-28-2016, 04:17 AM
Justin100
Justin100's Avatar
the sound hes experiencing was something "kind of similiar" except mines was deeper sounding from the exhaust during the break in period of my engine. it turned out to be piston slap though not really a big deal only happened during cold startup and once the car got warm my sound went away.
Old 04-28-2016, 04:28 PM
TeamZleep
TeamZleep's Avatar
Why in the hell would you rev the **** out of your car on a cold start?
Buuut... Start looking for a new engine. These meme's are killing me.
Old 04-28-2016, 04:41 PM
well then... here is more
Old 01-27-2019, 08:09 AM
Valdet HC
Valdet HC's Avatar
Default Same Problem
Hi, I wanted to ask you if you've solved, I have the same problem
Old 01-27-2019, 08:55 AM
Received 1,292 Likes on 1,016 Posts
Valdet - load up a video with sound of your engine. Bent rod / spun bearing ...
Old 01-27-2019, 10:25 AM
tmdz
tmdz's Avatar
@Valdet - The post is like 3 years old now so it’s unlikely you’ll get a reply but like Beal said just give us 30 secs of audio/video and we will take a look.
Old 01-27-2019, 01:36 PM
Valdet HC
Valdet HC's Avatar
Default Video My engine
This my Videos
CUL8ER
Engine Swaps
05-04-2016 10:34 AM
Crusade350z
05-04-2016 04:00 AM
Arrtus
04-27-2016 05:18 PM
35reilly
04-25-2016 03:37 AM
natedogg713
04-22-2016 02:40 PM
Quick Reply: 350Z engine strong knocking sound after revving
