Tuning Reflashes, Piggybacks, Standalone ECUs
Got my '06 tuned
Old Jun 19, 2007 | 07:44 AM
  #81
EM-EFER's Avatar
EM-EFER
Long tube headers
Stillen test pipes
380 INJECTORS
How do you have long tube headers and test pipes? How is this possible?
Why 380 injectors on a NA car? Your car can't utilize them without engine management and those are still to large and would need to be scaled down.
Something doesn't sound right..
Old Jun 19, 2007 | 07:49 AM
  #82
iStan's Avatar
iStan
ZR
^ I'm guessing his custom single exhaust is allowing it to happen.
Old Jun 19, 2007 | 09:36 AM
  #83
EM-EFER's Avatar
EM-EFER
LOL I am sure of it.
There are only two long tube header companies for the Z. One no longer makes them and the other you can't get in the US.
I wondering if he uses all 4 of his 02 sensor holes as well
Old Jun 19, 2007 | 10:01 AM
  #84
Lawy'dU's Avatar
Lawy'dU
Originally Posted by chris'smax
Not to bust your bubble but it has been track proven and dyno proven that the aem does loose power. Great numbers though. I am going to get my utec tuned as soon as school is over next week.
BTW what AFR did you tune for?
No it doesn't. You guys are full of it.
Old Jun 19, 2007 | 10:03 AM
  #85
kostat26's Avatar
kostat26
its been proven a billion times, but hey its ur money.
Old Jun 19, 2007 | 10:35 PM
  #86
chris'smax's Avatar
chris'smax
SUUUUURRRREEE!!! Keep lying to yourself
Old Jun 20, 2007 | 08:49 AM
  #87
EM-EFER's Avatar
EM-EFER
Originally Posted by ZULATER06
Injen CAI SP1986 w/streamiline filter
UR Pulley set
Long tube headers
Stillen test pipes
Custom Single exhaust
Kinetix SSV intake manifold
Throttle body spacer
380 Injectors
Apex'I SAFC-II
Anyways, I will go to another dyno this weekend and will let you guys know what happened as far as numbers go.
Bumpity on my questions about those mods.
Old Jun 21, 2007 | 08:39 AM
  #88
gothchick's Avatar
gothchick
Bump again...
Going from 290cc (stock) injectors to 380cc... NA... No UTEC, F-Con, E-Manage, Etc? Interesting. You must be running *quite* rich on your AFR's... Do you foul many plugs? Lol!
Some pics of those longtube headers mated to the TPs would be nice too... :-)
Old Jun 22, 2007 | 07:13 AM
  #89
Alberto's Avatar
Alberto
Cranky FI Owner
I dyno'd my AEM vs Pop-charger on my car around 3 years ago, AND I track tested both set-ups. I posted my experiences if you wish to see that your wrong you can search them on the forums. If you wish to believe your $200 AEM intake provides anything else besides a nice engine note dont search for it.
Zulater-we need an update! I want my $20 I need beer $$$ for the weekend
Old Jun 22, 2007 | 07:14 AM
  #90
doug's Avatar
doug
90% of Lawy'dU posts are inaccurate.. i was hoping by now he would stop posting and do more reseach.. but i guess nothing has change
Old Jun 27, 2007 | 12:32 PM
  #91
Lawy'dU's Avatar
Lawy'dU
show me what Else I've been wrong on?
Old Jun 28, 2007 | 12:12 AM
  #92
ZULATER06's Avatar
ZULATER06
Wow, alot of progress since the last time i posted. I do have a throttle body spacer, I have borla headers and i was told they are long tube headers(maybe they are not), and I have an Apex'I SAFC-II tuned by Dynocomp By Richard the owner if anyone here knows him. And about the Dyno you guys will see it i promise. Now if you guys are gonna keep talkin smack just go for it. I know how you guys always pick on the NOOBS. I honestly dont care. If you dont watch the weather channel you should try it sometime. Its been 115 degrees in AZ for the last week. I am not blowin up my motor to amuse you. And injectors are for the 100 shot and Utec goin in pretty soon.
Old Jul 2, 2007 | 04:06 PM
  #93
doug's Avatar
doug
https://my350z.com/forum/showpost.ph...9&postcount=21
https://my350z.com/forum/showpost.ph...1&postcount=42
https://my350z.com/forum/showpost.ph...04&postcount=7
need i say more?
Old Jul 3, 2007 | 08:57 AM
  #94
Road Warrior's Avatar
Road Warrior
Old Jul 9, 2007 | 05:22 AM
  #95
Alberto's Avatar
Alberto
Cranky FI Owner
LMAO-Doug cracks me up
ZULATER06-so NA engine blow up in 115 degree heat? Answer is NO, and if you were running N20 you should know it would considerably cool your intake charge. You have no excuse go to a Dynojet and post SAE Corrected #'s...
Old Aug 12, 2007 | 09:38 AM
  #96
i8acobra's Avatar
i8acobra
Just a little update...
Road tuned the car last night in Speed-Density. WOW, much better. Car pulls harder and accelerates much smoother. There's no longer a feeling of building power, it's just smooth all the way through. This is mostly due to the timing changes. We added about 6 degrees of timing. I have one map saved with just the fuel changes and one with fuel and timing. The one with both is the smoother one.
Only problem is that the transition from MAF to MAP control (I have it set at 3000 rpm and -2.5 psi) is a bit wonky. Problem is that the UTEC was never intended to run an NA car in SD mode. The only load cell column that's usable is the 10% column. It's be great if the UTEC had a 5% column as well. Also, the car loads up when the throttle is slammed shut. I'm guessing that the ECU is not holding the throttle body open a crack to burn off the extra fuel in the runners when the UTEC is controlling the fueling. This does have a bit of a benefit though... Shifts (both up and down) are much smoother now that I can control the TB. It's almost like having a cable operated TB.
I'm slapping on some 1" shorter than stock drag-radials and hitting the track Wed night. I'll post up the times. Next thing to do is install my S-7 cams and retune. I'll get dyno numbers after the cam install.
Old Aug 13, 2007 | 04:16 AM
  #97
Alberto's Avatar
Alberto
Cranky FI Owner
Good luck at the track...
Old Aug 13, 2007 | 12:12 PM
  #98
gothchick's Avatar
gothchick
Awesome! Thanks for the update, and good luck at the track/ dyno~ :-)
Old Aug 13, 2007 | 03:59 PM
  #99
i8acobra's Avatar
i8acobra
Temp corrections own me. Need to make sure you use them in SD mode. 20 degrees hotter today than when I tuned. Car pegged the WB sensor at 10:1.
Old Aug 18, 2007 | 08:34 AM
  #100
RBlover69's Avatar
RBlover69
nice revup man, let us know what comes out of it. Im dying to see what the S7 cams do to a revup with all the mods..must be at the elusive 300rwhp mark.
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
