Big rubber block.. What does it do?
Old 07-21-2017, 07:45 AM
CK_32
CK_32's Avatar
Default Big rubber block.. What does it do?
Wtf is this big rubber spring loaded black rubber block on the driver side just under the intake box, in the wheel well?
Im trying to route my Boosted 6266 kit but the charge pipe hits this and sits way lower than I want it to.
Do we need this? Wtf is it and wtf does it do?
i tried to google 350z rubber block and got nothing. Shocker right?
Old 07-21-2017, 07:46 AM
CK_32
CK_32's Avatar
And no I don't have a pic of it. Hopefully someone will know what I'm talking about with that vague discription.
If not I'll get a pic when I get home tonight.
Old 07-21-2017, 07:59 AM
HOMiEZ
HOMiEZ's Avatar
You got an HR or DE? I just pulled my intake off this past weekend on my DE and did not notice what you're describing.
Old 07-21-2017, 08:21 AM
CK_32
CK_32's Avatar
VQ35DE
Right where your box is, under the sub frame. Look again you'll see it. You have to look from below or from the wheel well side.
its literally a rubber block behind the wheel liner.
Old 07-21-2017, 08:30 AM
BluestreamDE
BluestreamDE's Avatar
I'm trying to figure out what u are talking about but maybe this will help.
Is it the block in the yellow circle?
Old 07-21-2017, 08:52 AM
CK_32
CK_32's Avatar
Its just out of frame on in this picture.
But the little black plastic thing in the bottom center of the photo. Just below that is this huge spring loaded rubber block.
Old 07-21-2017, 10:13 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Ive done my share of taking apart and I cant think pf what you could be talking about... Maybe its a leftover piece of the car that smashed into yours...
Here is an under shot of mine
Old 07-21-2017, 10:18 AM
dboyzalter
dboyzalter's Avatar
Here is another pic to help identify..
Old 07-21-2017, 12:27 PM
icer5160
icer5160's Avatar
Is it the thing mounted on top of your brake caliper?
Old 07-21-2017, 12:28 PM
HOMiEZ
HOMiEZ's Avatar
You trolling us or what? Why would you post a picture that doesn't show the thing you're talking about?
icer5160 (07-21-2017)
Old 07-21-2017, 12:31 PM
icer5160
icer5160's Avatar
Otherwise, the only other thing I can think of being there would be a steering bump stop. Or some kind of sway bar bushing. Would be great if you could take a photo of it in the frame. Otherwise we are all just guessing here.
Old 07-21-2017, 12:49 PM
It's a chassis counterweight. The front one is exclusive to the ZR whereas all Zs have two additional counterweights towards the middle (near trans mount or incorporated into it) and rear of the chassis on the opposite side as the front one.
Do not recommend it's removal
- but it won't hurt anything too badly - as it is there to "correct" the chassis harmonics so as to isolate the car from inherent road noise, bumps, grinds; and, due to a change to a more "natural" or "neutral" harmonic frequency, it also helps to reduce chassis flex and helps a bit to smoothen the ride.
Work your intake around it.
Not sure it if this was an intended design element or "a fix to a funk up after the chassis was built and tested"; but it was put there by Nissan Engineering so you can trust it (at least to a degree and moreso than home hacks who think they know better.)
EDIT: It should be noted that this is NOT exclusive to Nissan or 350Z or even just cars. All (or many) mfgrs use such "tuned mass dampers" in a wide variety of vehicles, machinery, etc. Nothing unusual about them.
Old 07-22-2017, 08:33 AM
Atreyu'z 350
Atreyu'z 350's Avatar
Another one of Nissan's Z33 R&D outcomes.
Old 07-22-2017, 12:20 PM
tampa_joey
tampa_joey's Avatar
picture and discussion of it....
https://my350z.com/forum/forced-indu...terweight.html
Old 07-22-2017, 12:27 PM
tampa_joey
tampa_joey's Avatar
oh- and a longer discussion about it....
https://my350z.com/forum/2003-2009-n...-weight-2.html
Old 07-22-2017, 01:01 PM
ridered929rr
ridered929rr's Avatar
How tf did you figure that out Mic?? Impressive
Old 07-22-2017, 01:13 PM
My alter ego persona's name was Claire B. Voyunt.
Nahhhh, I commented on this same one a couple years ago (I think in the threads noted above somewhere) after doing some research on "the big black box".
But I remember this as a young man.... my dad was a Naval Engineer and on one of the tours of a particular battle wagon he'd overhauled, he gave me a lesson on "harmonics" (owing to their use of same in ships and their subsystems), explaining it in as close to layman's terms as he could. Like anything else, none of it made sense until I was in college and took physics (or some such) where frequencies and harmonics came into discussion. Then, be like..... "Ohhhhhhhhhhh, nowwwwwwwwww I get it."
And Pops didn't think I was listening.
Now every time I see a tuning fork (not s'much anymore thanks to digital tuners), I think of Pops. Hahaha.
CK_32 (07-23-2017)
Old 07-22-2017, 05:20 PM
CK_32
CK_32's Avatar
Mic you're the man!
took pics but I'm late to the party.
http://i124.photobucket.com/albums/p14/sportin3s/3D8B27F4-66F8-4CF9-BA30-8E2C9662D0C0_zpsf4xpdrgu.jpg
http://i124.photobucket.com/albums/p14/sportin3s/E47D30DB-9872-4EEA-907E-A32C4A1DCD6B_zpsf53gfi7o.jpg
Old 07-22-2017, 06:43 PM
CK_32
CK_32's Avatar
I'd like to leave it but I think it's interfering with my turbo kit and why the charge pipe is touching the steering rack
Might have to go. Don't think Sasha planned for that damper
Old 07-22-2017, 10:18 PM
If you are installing a turbo, it's not much of a concern
