Brake pad setups
Brake pad setups
Sup gents, sorry I haven't been around this year (not that anybody cares). Bought a house in Feb, and its drained me of $20k cash. not a lot of room for the track this year. buuuuttt...
Im going to squeeze in summit main next weekend. here's the question..
Currently running carbon tech xp 10 Front and xp 8 in the rear, oem blanks, 06 base non brembo, with 320 tread tires (nitto 555). I'm currently having some trouble with brake balancing (i think). On Summit main turn 1 and turn 5 and several turn on Shenandoah, the rear ABS is engaging some. But I generally don't get any ABS engagement in the front. Would anyone be opposed to trying to go up to XP 12 up front? Would that maybe balance this out? Thoughts, suggestions, and trolls GO!
are you familiar with summit main? i currently brake at or in between markers 4/3 on turn 1. ive tried marker 3 before, but my current setup doesn't allow that. i pretty much barely make it. (which is probably where driving to max potential becomes involved, but im not ready to be at 100% all the time. id rather be at a safer 90%)
Entering. i haven't messed with trail braking yet
Factory nismo suspension, hotchkins sways, full stiff up front, lowest in rear.
outside of that i dont know. I thought of your suggestion as well. A spec Miata buddy just through in the question of wheel alignment. Too much toe in under the brake load might make it go squirrely.
Not sure. I can add more info.
While I have experience at Summit Point Raceway (SPR), it's been years since I raced there. More importantly, I've never used Carbotech and have no realistic suggestions on which compound to use. It sounds like you're going in deep enough at T1, as SPR has a long, undulating front straight and I bet you're seeing 130 MPH+ before threshold braking.
With that in mind, why not call Carbotech and get their suggestions? They'll be busy at the SCCA Runoffs at Indy next week, but their tech rep is who I'd hit up.
rizeld (09-22-2017)
