350Z HR tuning support now available through HP Tuners
This is for the operating system EV52D (2008 350Z). I counted the number at one point, IIRC is something like 150 parameters to work with. The 370Z has a few more parameters, just shy of 200.
We also have actual knock count and knock degrees of feedback to log in our scanner, which is different from our competition
Evan,
Does your tuning package allow for control over deceleration fuel cut and throttle closing decay rate, specifically after the driver lifts off the throttle and the ECU maintains minimal throttle opening for a specific duration?
Thanks
Thanks
Not currently, but if you end up working on a car and think it's necessary, submit a support ticket. One other differentiating thing that we have is we give you the option to request parameters be added. The current support isn't necessarily the final support. If those parameters exist as OEM parameters, then they will get added.
All I want to know, will it have the option for a flex fuel sensor
Beeker
08-05-2006 11:33 AM
