Z1 Motorsports M-Spec exhaust not clearing diff cross brace
Old 06-20-2018, 05:27 PM
absurdparadox
absurdparadox's Avatar
Default Z1 Motorsports M-Spec exhaust not clearing diff cross brace
Hey guys, I am attempting to install the z1 performance m-spec single exhaust, and I am having a clearance problem at the cross member that the diff mounts to (see attached pic).
I've loosened my entire exhaust but I can't seem to find a combination that actually gets it to clear this. Anyone got any good advice here? Thanks!
Attached Thumbnails Z1 Motorsports M-Spec exhaust not clearing diff cross brace-img_20180619_203202943.jpg
Old 06-20-2018, 05:47 PM
Received 9,060 Likes on 6,523 Posts
Have you tried reversing the ends of that section of pipe
Old 06-20-2018, 05:49 PM
absurdparadox
It can definitely only go one way, has a flange on one side, and the muffler connects with a slip joint or whatever you call it (pipe goes into muffler, then uses a t-bolt clamp around the pipe)
Old 06-21-2018, 01:51 AM
Call z1
Old 06-21-2018, 04:55 AM
A-Town-Z
A-Town-Z's Avatar
What y-pipe are you running?
Old 06-21-2018, 05:02 AM
btw absurd, your diff bushing is blown out
Old 06-21-2018, 05:09 AM
absurdparadox
Call z1
Haha yeah, I did email them yesterday -- was hoping for a quick solution if someone ran into the same problem specific to this exhaust.
Motordyne XYZ with resonator
Yup, it's on the list! Thanks for looking out!
Old 06-21-2018, 05:11 AM
i finally looked at the exhaust, and yeah its pretty obvious it only goes one way... unless i am just retarded
Old 06-29-2018, 01:15 PM
Z33Garage
Z33Garage's Avatar
So I have their dual setup and even that had some issues. Nothing I would not fix but I did have to bend their hanger a bit for it to work.
Also the clamps for the muffler sections are garbage : /
Old 07-01-2018, 10:23 AM
guitman32
guitman32's Avatar
I run several Z1 products so not hating, but that fits worse than the ISR single...which fits great except for resting on the crossmember.
Did Z1 respond?
Old 07-01-2018, 06:24 PM
absurdparadox
Did Z1 respond?
Yeah, they said to just bend the hanger that goes around the muffler, which has seemed to work.
Old 07-01-2018, 06:25 PM
absurdparadox
Yeah, I like Z1, but this exhaust feels overpriced at the $500ish I paid for it. I wish I had just cut the cone-tip off my old Motordyne Shockwave and had a custom muffler added, etc.
ShineMaster
03-01-2013 05:13 AM
Quick Reply: Z1 Motorsports M-Spec exhaust not clearing diff cross brace
