Stock Steering wheel with harness?
Old 04-23-2019, 07:41 AM
coletrickle74
coletrickle74's Avatar
Default Stock Steering wheel with harness?
Usually the opposite gets asked and it turns into a safety debate. But what about using the stock steering wheel with a harness?
My Kirk rollbar is on its way. I already have the seat, 6 point harness, and a hans device. I completely forgot about the wheel.
Old 04-23-2019, 08:24 AM
dkmura
dkmura's Avatar
The racing harness will not be a problem, but any time you are in a situation where both an airbag and helmet are being used concurrently, there is a chance the airbag could deploy and cause injury. Why? The explosive airbag could impact in the jaw section of a full face helmet and slam the helmet into your face. If you want to avoid this, simply deactivate and remove the airbag from your OEM steering wheel.
Old 04-23-2019, 08:41 AM
jcrick
jcrick's Avatar
I agree. And let's not forget to mention any unintentional deployment of the airbag due to an off track incident. An airbag deploying unexpectedly could turn a situation from controlled to totalled.
Old 04-23-2019, 09:03 AM
coletrickle74
Thanks for the input. That got me thinking. I bought a resistor for when I replace the OEM seat. I believe its to keep the airbag light off and the system functional.
Sounds like I could just unplug the seat resistor when I go to the track and it should disable the airbags right?
I got carried away and bought to much stuff so I'm putting a quick release and a new wheel on hold haha
Old 04-23-2019, 01:04 PM
dkmura
dkmura's Avatar
No- when you unplug the airbag itself, you'll still get the airbag light on your dash.
coletrickle74 (04-23-2019)
Old 04-23-2019, 02:31 PM
coletrickle74
Thanks, I'll probably do that for the first few events and see how long I can last before buying a setup.
gt3
202
07-03-2023 06:43 PM
JDMHolic
06-02-2011 12:45 PM
boomfranco
12-08-2009 03:39 PM
kbiz
12-12-2005 05:43 PM
bruce350z
11-08-2005 04:05 PM
Quick Reply: Stock Steering wheel with harness?
