Slip Light Flashes when Driving at Highway Speeds
Hello everyone,
Recently I acquired a new set of wheels with these specs:
I would go back to my OEM wheels and tires, but rims itself are rusting out and are unable to hold air.
Now I am stumped on what I should do. Should I find a new set of OEM wheels and put those back on? Can I just roll the rear fenders and put the 245/45/18's on the rear? Should I get my TCS recalibrated by Z Garage? I would like to keep the wheels I currently have and not have to roll the fenders, but I would also like to know what would be the cheapest way to fix this issue. Thanks!
- 18"x8" + 20 || 245/40/18 - Front wheels
- 18"x9" + 18 || 245/40/18 - Rear wheels
![](https://my350z.com/forum/images/ranks/moderator.gif)
Put the 245 tire on the 9" wheel and test fit on left rear. Shouldn't be an issue. If you were going 275, might be close but no issue. If you need to roll and seal, I've got a guy in your area (if he's still doing it (been a while).
245/45-18 on that wheel will fit no issue and not rub. Go back to discount and have them install the tires.
245/40 front and 245/45 rear is a great handling combo
you can even run that same 18x9:up front without issue
I went back to ask if they’ll install it. They said they won’t install them because used tires are a liability for them. They also refused to install it because they still believe it’ll rub.
At this point I might just sell these wheels I currently have and buy a new/used set of stock wheels and tires. If anyone else has any ideas, please let me know.
Worst tire size choice ever. 1" shorter than stock on the rears and 0.3" on the front. That shop got you good with unloading tire sizes no one wanted.
https://tiresize.com/calculator/
This is your friend.
Stay at stock diameter.
