06 HID Lights
Performance Nissan
Performance Nissan
Originally Posted by El Guy
Yeah what is it that i need for the convertion, I have a 05 Base. You think Performance will have the part numbers that i need.
Originally Posted by Andy@Performance
You cannot directly fit any OEM HID headlight to a Base, hard wiring will be required. As far as any other Z equipped with HID from the factory, the kouki headlights will be a direct fit and connection with no modifications needed, I have already done this on my Z.
So what is the price for The Nissan OEM lcomplete lights and what is the price for Kouki complete kit?
Originally Posted by S1 350Z
are housings only available?
Originally Posted by THE TECH
Inquiring minds want to know!! Can't we just use our stock HID with the 06 housings? They have to be available separately...and for much cheaper!
Performance Nissan
Performance Nissan
The housing alone will not work, you will have to purchase the whole assembly and the reason being is that the zenki model ballast and HID bulbs do not work with the kouki housing. If you only purchase the kouki housing, the bulbs and the rest of the hardware thats left on your zenki will not work. Ive researched this and all the part numbers are different.
Ballats are universal, they 03-05 ballasts would work with the 06 lights. Also the 03-05 d2r bulbs WILL work on the 06 lights you just have to file a slot in the base for fitment and scratch off the covering on the bulbs it self (it is there to stop glare in reflector based headlights but your going to full projection.)
I have been wanting the 06 lights with out ballasts and bulbs for some time but no luck. =( I would like to open them up and swap in a clear lense also for the more aggressive flicker and color at the cut off.
EDIT: if you dont want to scratch off the small patches on the d2r bulbs you can just leave them but you will be putting out around 2900 lumens (sp) instead of 3200.
Performance Nissan
Performance Nissan
