Help!!! Broken Stud
Old Oct 25, 2006 | 04:05 PM
Joey47's Avatar
Joey47
Default Help!!! Broken Stud
Any one close by to Carson that can help me replace a wheel stud. I really don't feel comfortable driving on 4 lugs. I can treat you to lunch or something.
Old Oct 25, 2006 | 04:11 PM
mrtomcat's Avatar
mrtomcat
I drove on 4 lugs many a times after track days...
performance nissan can change that for you in about 30 minutes
Old Oct 25, 2006 | 04:27 PM
Joey47's Avatar
Joey47
how much do they ususally charge?
Old Oct 25, 2006 | 04:43 PM
05-Z's Avatar
05-Z
One of these days I'll change my broken one out, it's been 5 months...
Old Oct 25, 2006 | 04:52 PM
Joey47's Avatar
Joey47
are you serious. you dont feel wary or scared that your wheel will fall off
Old Oct 25, 2006 | 04:54 PM
plumpzz's Avatar
plumpzz
Honestly you can survive on 2. You only need 2 physically. 5 is for saftey and stability. Get it changed, but theres no rush..
Old Oct 25, 2006 | 05:19 PM
mrtomcat's Avatar
mrtomcat
it's like $50 or something around that.
Old Oct 25, 2006 | 05:34 PM
Joey47's Avatar
Joey47
i just went to the local dealer "superior nissan" in carson and they were going to charge me 100 plus the stud. those guys suck
Old Oct 26, 2006 | 03:50 PM
skip2daZ's Avatar
skip2daZ
Call Status. They'll do it for you... Best of all, you can even go there on Sunday since they're open 7 days a week.
Old Dec 4, 2006 | 08:41 AM
Shift_Z33's Avatar
Shift_Z33
I have a stripped stud on the drivers rear wheel. Some asshat used an impact gun on my lugs. Can someone explain how to change it out or give me a link to it. TIA guys
Old Dec 4, 2006 | 04:46 PM
mrtomcat's Avatar
mrtomcat
it's actually very easy we had to do it at the track a few weeks back and from now on I'll do it myself.
take the wheel off, take off the Caliper (one nut on the top and one on the bottom, I believe it needs a 13/16 socket. This is the only tough part getting those loose since you can't fit in a big enough wrench to have leverage so we used a rubber hammer to loosen it by gently hitting the wrench.
once the caliper is off you can take off the rotor (make sure the hand break is off otherwise the rotor won't come off).
then use a rubber hammer to push the bad stud out (you don't want to mesh in the stud head or it'll be hell to get out. Once out put in the new one (you might have to fiddle around a bit getting this in but it works.
After that use a lug nut and tighten so that the stud will be seated correctly.
Put the rotor and the caliper back on (not sure what the torque needs to be for that), put the wheel on and tighten. Drive the car a bit and then re-tighten.
that's it
if someone could post the torque for the caliper that would be appreciated
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
