so cal peeps do i need more brake fluid?
on
yesterday i was forced to do some hard braking to avoid a accident.. in doing so i noticed a minor noise like my ebrake was enabling also i saw my break light turn on.. is this normal?
just checked my brake fluid level.. its a little bit above the min line but not really close to the max.. do i need to add more? if so what kind?
i have attached some pictures if anyone could compare it with theres that would be great :]
click for larger picture
p.s. this is on a g35 but im sure its the same as the Z's
on
Your not suppose to add brake fluid. The noise you're hearing is probably the brake pad sensor touching the rotor. When you replace the brakes and push back the piston the fluid should come back up.
on
my brake pads on the front and rear are fairly new.. is it normal for the brake indicator to light up under heavy braking? it almost felt like the ebrake turned on to help me stop.. i know it sounds stupid -_-
Fill it up , when you replace the pads, just crack the bleed port before you push the piston in. This also help you keep fresh/fresher fluid in the caliper.
