Maxed out oil pressure guage
Old Apr 26, 2008 | 04:35 PM
UHATEIT's Avatar
UHATEIT
Default Maxed out oil pressure guage
Question on this. I was driving on the freeway and yes it is hot outside and I rarely ever use my AC but I did today, and I usually don't monitor my oil pressure meter at all. But on the freeway it was maxed out at all the way past the 120.
I pulled over on the side and checked my oil, appears to be fine. I know I have an oil leak but it's nothing major it's pretty minor. But I drove home the rest of the way very slow at low RPMs.
Wondering if getting that maxed out guage is a bad thing??? I have searched the threads and found a few things, most people say low pressure is bad and high is alright. Any feelings on this? Could this be because of the extreme heat outside and using my AC?
Old Apr 26, 2008 | 05:52 PM
jwttz's Avatar
jwttz
It might be your oil pressure sending unit. Mine went bad and did the same thing. I belive its located on the oil filter adapter Or around there. Make sure its connected as well.
Old Apr 26, 2008 | 05:56 PM
UHATEIT's Avatar
UHATEIT
when i stopped and idled it went to 120 and stayed there but when driving it immediately went up to maxing it out, so it's actually moving it should be connected. My car temp is fine tho.
any pic of what this thing may look like so I can try to check connection?
Old Apr 27, 2008 | 10:06 PM
xpl0de's Avatar
xpl0de
im pretty sure its supposed to max out if ur pushing ur vehicle...as u drive it should go up...
Old Apr 28, 2008 | 12:24 AM
SoldzMyZ's Avatar
SoldzMyZ
The oil pressure sending unit is connected to the cylinder metal part between your oil filter and your engine. There is connector plug and wires coming out of it so you can miss it.
Old Apr 28, 2008 | 08:19 AM
UHATEIT's Avatar
UHATEIT
back when I used to look at the meter it was usually around the middle (60) and would idle much lower than that. now it is idling at 120 and when driving at any rate is is maxed out
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
