Oil light at sharp turns
already did a search jsut want some feed back...
03 z supercharged.... so when i hit sharp turns my oil press.. drops to almost zero and oil light comes on... does same thing when i stop quickly drops crazy low... i check dip stick in morning after car has sat all night and oil levels seem fine dosnt help our dip stick sucks... dont want to over fill....
oil 10w-40 royal purple... at idle roughly right under 30 on gauge...
You may want to consider a larger oil pan, or a pan spacer in order to gain that extra qt. for added piece of mind. I've personally met three different people who blew their engines at tracks due to the same issue.
5W3O, MOBIL 1!!! Also, try slowing down a bit, kid! Saves gas, makes tires last longer & reduces risk of an accident. Going back to the oil part, oil flow is more important than viscocity; try the easier-flowing 5W3O, or even OW3O--
you'll be grateful to this old-timer when you shift to either of those grades.
There's a SUPER thread (I FORGOT THE NAME!), which explains it SOOO well,
m'friend! But, trust me, I went from 1OW3O, to 5W3O: NO regrets!!!!!!!!!!!!!!!!
____________________________________________________________ _____
'O4 Touing Coupe/13k!!!$2O,5OO!!!/NO FEATHERING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
