Brake Light and Battery Light ON HELP!
Old Sep 28, 2011 | 08:48 PM
xkevon's Avatar
xkevon
Default Brake Light and Battery Light ON HELP!
So I was driving on the freeway and suddenly my brake and battery light
turns on and then my steering wheel wouldn't turn. Can someone help me what could be wrong?
I've already checked all the fluids (brake, battery, steering)
and they are all full.
Old Sep 28, 2011 | 08:58 PM
LB350z07's Avatar
LB350z07
altenator probably
Old Sep 28, 2011 | 09:02 PM
xkevon's Avatar
xkevon
by any chance could a missing drive belt cause the malfunction of my steering wheel and the lights to come on?
Old Sep 28, 2011 | 09:54 PM
jnathan68's Avatar
jnathan68
When you say it won't turn, do you mean no matter how hard you try to turn the steering wheel, it won't move or turning the steering wheel is extremely tough and I have to put a lot of effort into making it turn?
Old Sep 28, 2011 | 10:55 PM
xkevon's Avatar
xkevon
its tough to turn the wheel but it turns.
Old Sep 28, 2011 | 11:10 PM
SuperBlack350z's Avatar
SuperBlack350z
something to do with the power steering.
Old Sep 28, 2011 | 11:15 PM
xkevon's Avatar
xkevon
I actually checked my car again and one of the belts is gone. Would that actually make the battery and brake lights turn on and cause the steering wheel not turn easily?
Old Sep 28, 2011 | 11:29 PM
2k6-z33's Avatar
2k6-z33
belt turns the altenator and the power steering pump...
Old Sep 29, 2011 | 04:32 AM
K-TownGuy's Avatar
K-TownGuy
If you're missing the belt cycling on the left hand side when facing the the engine bay, then you are missing the alternator, power steering belt. Just replace and you're good to go.
Old Sep 29, 2011 | 06:14 AM
jnathan68's Avatar
jnathan68
As others mentioned, yes, that is your problem. Just remember, with the alternator belt missing, you were/are running just on battery. If you ran the car at all after the belt came off, good idea to give the battery a charge.
Old Sep 30, 2011 | 09:31 AM
K-TownGuy's Avatar
K-TownGuy
+1 on the battery charge.
350z82
Oct 1, 2015 06:25 PM
