The Be All, End All Endlink for your Z and G!!!
Old Apr 25, 2008 | 11:29 AM
  #101
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
sorry man, we're out for now (waiting on a new batch) and won't be around this weekend
Old May 9, 2008 | 09:49 AM
  #102
Z1 Performance
Former Sponsor
up top - just got a FRESH batch of endlinks in stock today, and they are ready to go!!!!!!
Old May 12, 2008 | 02:17 PM
  #103
SteveZ's Avatar
SteveZ
Originally Posted by n1cK!
well, just got back from the track a couple of hours ago. the endlinks didn't break! no weird popping noises, clanking, nothing. smooth as OEM. after a full day of tracking (7 sessions at 20 minutes a piece!), everything is in one piece and the joints were still aligned (relative to the sway bar). since the sway bars were "neutralized," i didn't feel as if i was fighting the car anymore. steering feel was more responsive and the car had a quicker and smoother reaction to my steering inputs. if anyone is an avid track racer, or a weekend warrior, i highly recommend them!
Can't wait to try mine out at speed. n1cK, btw I noticed in your pics it looks like you put a thin maybe SS washer on the lower end link in front - I first used the OEM washer, looked too thick. Not enough threads engaged in the derlin locknut. So, I took off the washers on lower front. Just curious if you put your own in there...what a painless install, not having to remove the old ones was a plus, too, since I was replacing the sways same time. I wasn't able to formally adjust the preload, so I just evened up the sides best as I could w/o scales and gave them what should be a very small amount of preload, just to keep things snug.
Adam, the links are awesome, yet another leap forward in the handling for my car, very solid, turn in is sharp (I finally put on my front hotchkis sway same day), and response in side to side transitions is great!
Worth every penny.
Now I just have to look at what I really want for a primary DD/occasional track use in Springs and Dampers, but that's another thread...my '91 SE-R is my primary track car and have to keep the G more streetable than track
Old May 12, 2008 | 02:32 PM
  #104
n1cK!'s Avatar
n1cK!
Infiltrator!
steve, if i remember correctly, i only used what was in the kit. however, if you haven't put a washer down there, you should. just in case the nut spins, you don't want it spinning against the arm.
as far as adjusting preload, it's easy...if you had three joints between your shoulder and wrist rather than just your elbow if your car is too low, you could remove your front and rear bumper to gain better access to the endlinks.
Old May 12, 2008 | 03:21 PM
  #105
SteveZ's Avatar
SteveZ
Thanks, good advice. I'll pick up some thin washers - both the kit and oem left me a little concerned as the bolt did not reach the end of the nut, I think it should have enough threads to fully engage the nut.
The links aren't too bad to adjust but it would sure be a lot easier to get from under a drive-on rack like my alignment was done on. I have a lot of cone and right-angle wrenches from my MTB and road bike tools, even a right angle 7 for that center section.
Still, I am tempted to put a drop or two of blue loctite there after adjustment
Btw thanks for your track feedback, my backroads impressions with all of a day's use are really similar. I really like the bar/end-link combo, it's all smooth and helps keep those tires planted - I'm still getting used to that, 275 R/245F is a lot more rubber than I've had the last 4 years with the OEM 18's...but it's all good.
Well, except for the length of time tracks are open during the year in the NE, that's another subject.
Old May 13, 2008 | 09:20 AM
  #106
Z1 Performance
Former Sponsor
it only needs enough threads to engage the delrin
there should have been a supplement to the instructions included - might have forgot to put it in yours though. The washers are only for the mount to the swaybar, they are not needed for the control arm side
Old May 13, 2008 | 09:41 AM
  #107
SteveZ's Avatar
SteveZ
Thanks. I think there was a supplement now that you mention it, sometime between opening the box and my garage I probably separated from the parts. I'll check when I'm home this weekend.
So in the front, use the washers on the sway end, not the control arm. In the front I did not put washers on the sway bar end, oops. There were two extra washers, same size/type as the rear link washers, I did not use.
In the rear, use washers on both ends, at least that's what it comes with.
Got it, I think.
Old May 19, 2008 | 03:52 PM
  #108
Z1 Performance
Former Sponsor
bump!
Old May 20, 2008 | 09:38 PM
  #109
AUtigers350z's Avatar
AUtigers350z
Thanks for the help on AIM today I just ordered the rears a few minutes ago as they are the ones that are popping. I will pick up the fronts a little later.
Old May 23, 2008 | 08:55 AM
  #110
SteveZ's Avatar
SteveZ
Found it, dug deeper in the box. Flat washers for the sway bar end of the link - do they go on nut side (inner or toward motor side of bar end), or do they function as a spacer up front and go on the outside (toward the wheel) side of the bar?
Thanks, they're working out great!
Old May 23, 2008 | 08:59 AM
  #111
SteveZ's Avatar
SteveZ
Alot of people, including myself, have noticed the stock ones get very noisy over time, especially with aftermarket swaybars - particularly in areas that have rougher roads. The stock one is not a bad design mind you, its just not meant for severe duty, and has limited articulation...
When I pulled my rear stock links, the pivot joints on the lower ends were rough, you could feel them stick and there was a grinding feeling when you moved the pivot around. I drive the car 4x4 seasons, so no surprise, not after 45k miles and 4 years. I can easily see the OEM Links binding or breaking not to much longer than that...now, I'll make them into a wind chime or something ;D
Old May 23, 2008 | 01:50 PM
  #112
Z1 Performance
Former Sponsor
I don't have my car here to look at unfortunately...really should not matter where that washer goes though come to think of it, since its using a nyloc nut
almost all gone!!!!!
Old May 23, 2008 | 02:28 PM
  #113
n1cK!'s Avatar
n1cK!
Infiltrator!
maybe my pics on the second page will help
Old May 24, 2008 | 10:20 AM
  #114
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Adam, How do you feel these compare to the SPL Endlinks. The SPL's have been receiving some great reviews as well.
Old May 24, 2008 | 02:50 PM
  #115
Z1 Performance
Former Sponsor
I really don't think this is the appropriate question for me to answer except to say this. Just as we posted in the first thread, there is a reason this is the only endlink we offer for the Z. We even went so far as to do development work on our own unit, and part of that development included buying every available endlink from the half dozen or so units on the market worldwide. When we tested and used the Powergrid unit, we decided that this was the better mousetrap and exceeded anything else offered. When you find a winner, ya stick with it IMHO.
Old May 31, 2008 | 06:06 AM
  #116
Z1 Performance
Former Sponsor
just a few sets left
Old Jun 1, 2008 | 02:07 PM
  #117
SteveZ's Avatar
SteveZ
Just a pic installed in front, very happy with these combined with the Hotchkis sways.
Old Jun 1, 2008 | 02:09 PM
  #118
SteveZ's Avatar
SteveZ
I put the front flat washer on the nut side of the sway - the extra page said to use on the sway end of the link, that seemed to make the most sense.
Old Jun 1, 2008 | 08:03 PM
  #119
turismo's Avatar
turismo
Anymore in stock?
Old Jun 2, 2008 | 03:59 AM
  #120
Z1 Performance
Former Sponsor
couple sets left yes
