[Houston]: Building my VQ35DE for more boost...
Old Feb 15, 2012 | 10:33 AM
  #81
dikspiel's Avatar
dikspiel
Chestons Toilet
i have +22 offset 10.5 wheels running a KDW 295x35 with no problems. KDW's run large so it is more like a 305x35 from other mfg's.
Old Feb 15, 2012 | 05:49 PM
  #82
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Are you going to be running spacers in the front? I don't know what the rear is going to look like but that offset doesn't look particularly aggressive, either. I guess it all depends on how much you're dropped as well.
No spacers. I'll be lowered on Tein Comfort Sports and not slammed. I'm not into the HellFlush/Stance look. HellaFunctional Because Race Car!
Originally Posted by str8dum1
you sure that +34 is going to clear the inner suspension with a 305?
I have 11" rears that were +39 and rubbed on my coilovers. had to add a +12mm spacer.
If you are getting custom wheels, you dont want to have to use spacers. The offsets in the front are terrible as well. I run 9.5 +20 with a 275 with less than 1.5* camber
just saying.... those wheels are alot of money and i think you will be unhappy with the way they fit.
I feel confident that HRE picked the right offsets to fit the wheel/tire combo to clear my StopTechs and suspention.
Old Feb 15, 2012 | 08:16 PM
  #83
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I have a much more aggressive offset in the front (9.5" +12 with 265s.. 285s rubbed with just under -2º of camber) and the top of my fender arch was at 25.25" so it's pretty low. You're probably not as lowered as me, but I still think the offsets are a little weak (I hate the hellaflush **** too).
When my Z was stock height, I think +30s worked well. After a pretty mild drop with the Hotchkis springs (.6" F and .75" R drop), it looked pretty sunken in. After I lowered it more with coilovers, I had to add 25mm spacers (my old wheels).
Old Feb 15, 2012 | 08:28 PM
  #84
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well the good (maybe bad) thing about having HRE pick them is if they don't work they'll have to replace the wheel. Guess we'll see. I sent my recommendations; +15/+22 front and +25 rear. But like my vendor said, have HRE pick them that way they'll have to replace them. Guess we'll find out in a couple weeks.
If you look at the picture of that white Z he has a +31 and +30 running a 275/30 & 305/30 lowered on Tokico Spings and Shocks.
Old Feb 15, 2012 | 08:34 PM
  #85
3hree5ive0ero
Retired Admin
Ah, well, that's cool then.
I just looked at the white Z again and it looks like you're not really looking for perfect/near flush (not just hellaflush)..? If so, then with a mild drop, you'll probably be where you'd want it to be.
Old Feb 16, 2012 | 09:06 AM
  #86
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I e-mailed my vendor about the wheels offset(s) and he brough up a good point. These wheels are concaved. So they will be pushed outward from the hub. So we'll see how they look/fit when they arrive. Again I gave him/HRE the tire sizes I want to run and the brake diagrams for my StopTechs. I'm sure HRE has some computer program that makes sure they'll fit.
Old Feb 16, 2012 | 09:09 AM
  #87
str8dum1's Avatar
str8dum1
concavity doesnt matter how far the outer and inner side of the rim sit.
I doubt HRE will let you return anything once you mount tires.....
Old Feb 17, 2012 | 06:15 AM
  #88
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Spoke with my vendor, who spoke with HRE engineering and assured that this will fit and be best offsets for that wheel and tire sizes.
Old Feb 17, 2012 | 06:26 AM
  #89
dikspiel's Avatar
dikspiel
Chestons Toilet
the offsets look like g37 fitment
Old Feb 17, 2012 | 06:29 AM
  #90
dikspiel's Avatar
dikspiel
Chestons Toilet
I think your wheels may tuck in a little even with the wider width. Mine sit very close to the fender, esp in the rear.
Your offset:
Mine (+22 rear/+12 front):
Old Feb 17, 2012 | 08:15 AM
  #91
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Yeah they'll be tucked in more. Based on the computer diagrams I was able to play with the tire patch will be more centered versus pushed out, i.e. like yours.
But um... Why HRE??? How about a 20x11 weighting in at only 22.4lbs!
http://www.flickr.com/photos/hrewheels/6876814885/http://www.flickr.com/photos/hrewheels/6876814885/ by http://www.flickr.com/people/hrewheels/, on Flickr
Old Feb 19, 2012 | 10:47 AM
  #92
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Update:
Was talking directly with a HRE employee and he recommended a more aggressive offset(s). I'm not gonna lie part of me was/is concern about them. I let my vendor know that we're working on the fitments.
I think we need to get you a more aggressive configuration.
I believe the fronts need to be moved out, I’ll check on the rears.
Remember that when people call in, our recommendations are what we call Fitment1. But like the 370Z I posted, that is more like a Fitment2. Many customers don’t understand F2 level might require camber/rolling fenders etc. But typically F2 is pretty safe also.
I’ll get back to you Tuesday.
Old Feb 19, 2012 | 11:34 AM
  #93
3hree5ive0ero
Retired Admin
LOL @ whoever it was that recommended the weak offsets
Old Feb 19, 2012 | 12:02 PM
  #94
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I will admit I almost had a $6k
Just glad I was able to talked to someone, hopefully, before it is/was too late.
Funny thing is I even recommended to my vendor a +22 or +15 front & +25 rear. So now I'm curious to see what the new offset recommendation(s) will be.
Old Feb 21, 2012 | 06:09 PM
  #95
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Ordered:
~ Tommy Kaira Hebi Bebi Shift ****
~ 4-TPMS Sensors
Engine is still at the machine shop.
Old Feb 22, 2012 | 09:00 AM
  #96
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OK... So I just got off the phone with HRE. The original sizes and offsets I was suggested was; 19x9.5 +32 (265/30) & 19x11 +34 (305/30). I questioned this and was told they will fit. Well I got in touch with Lon at HRE via another forum. Told him the sizes/offsets and said they don't sound aggressive enough. So we shot e-mails back-and-forth. Anyhow... New offsets for my HRE P43SC are; 19x9.5 +20 (255or 265/30) & 19x11 +25 (305/30).
Old Feb 22, 2012 | 10:33 AM
  #97
3hree5ive0ero
Retired Admin
Still not "aggressive," but it'll look nice with a mild drop.
Old Feb 22, 2012 | 10:36 AM
  #98
dikspiel's Avatar
dikspiel
Chestons Toilet
That seems much better OP, 3hree5ive0ero is a player hater.
  #99
Robert_K's Avatar
Robert_K
Didn't Go Cheap
LOL This guy!^^
Old Feb 22, 2012 | 10:48 AM
  #100
3hree5ive0ero
Retired Admin
His Z's already sick. I gotta hate where I can.
