UTEC and Larger injectors at idle
Old Jun 11, 2006 | 02:33 AM
MR RIZK's Avatar
MR RIZK
Default UTEC and Larger injectors at idle
With the UTEC how does it control the injectors below the cut in point? What I undertsand is that the utec will cut in at a certain rpm and then take control but if you run larger injectors say 510's in my case how can I reduce the pulse/duration before the utec cuts in?
Michael
Old Jun 11, 2006 | 03:04 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
there is a setting for injector compensation, if that doesnt work you can alter the maf voltage percentage to accomodate...
Old Jun 11, 2006 | 05:29 PM
MR RIZK's Avatar
MR RIZK
Ahh okay so at idle the utec works as a interceptor
Old Jun 11, 2006 | 05:34 PM
Audible Mayhem
My350z
unless you are in open threshold (in speed density) then the utec is pretty much an interceptor...
Old Jun 14, 2006 | 07:34 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Michael
Is this a forced induction setup, or NA.
Old Jun 14, 2006 | 10:04 PM
baptist's Avatar
baptist
I would like to know the answer to this, also.
Old Jun 15, 2006 | 05:21 AM
Sharif@Forged
Forged Performance
Since you are running 510 injectors, I'll assume this is an FI setup.
The stock ECU controls the engine during start-up, idle, and cruise. During these conditions injector scaling is handling by the UTEC. At a certain user configurable point (RPM/TPS/PSI), the UTEC takes over, and complete controls fuel and timing. When properly tuned, the transition is completely seamless to the driver.
Old Jun 15, 2006 | 06:47 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
You can tell the UTEC to scale your injectors AND/OR you can tweak the 0 load column fuel values which are basically piggyback style (add/subtract from the ecu values).
So you can specify that the injectors are 510's and the ECU is set for stock size or 380's or whatever it is flashed for. I have 550's and idle is fine. I tried scaling but just tweaking the 0 load column values (piggyback style) worked better for me.
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
