UTEC/ECU; Having Trouble Installing Unit
Old Dec 19, 2006 | 09:19 PM
Barzten1's Avatar
Barzten1
Default UTEC/ECU; Having Trouble Installing Unit
Anybody else have trouble fitting back the ECU and UTEC back under the dash? I can't get mine to fit without possibly breaking something. I already pulled a wire loose. Any help or pics please.
Old Dec 20, 2006 | 05:35 AM
Barzten1's Avatar
Barzten1
Old Dec 20, 2006 | 09:02 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
dont do it the way they say, just take out the stock ecu and the utec, bolt the stock ecu to the utec with the studs coming out of the utec, aim all the plugs down towards the ground for later easy access and zip tie it up a few good times...
trust me, its much better
if you have a G35 its even harder
Old Apr 2, 2007 | 12:47 PM
killerlexus's Avatar
killerlexus
Banned for Scamming
Old Apr 4, 2007 | 02:42 PM
SmokyTyrz's Avatar
SmokyTyrz
You need to cut a notch out of the bottom bracket for the bottom attachment bolt. It will allow you to bolt the bracket down without having to "force" the entire assembly so the bolt matches with the hole on the bracket.
Hope that helps.
Old Apr 27, 2007 | 05:45 AM
RKnight's Avatar
RKnight
Wish there was a post in the DIY section with pictures of this install.
Old Apr 27, 2007 | 07:57 AM
SmokyTyrz's Avatar
SmokyTyrz
The UTEC manual covers 99% of it. Cutting this notch in the ECU bracket is the only "missing step". Of course, TXS may have a technique making it possible to slip the ECU/UTEC combo into the footwell without cutting a notch in the bracket, but it is unknown to anyone else. Cutting the notch makes it 100% easier to finish the install.
If TXS added this one step and pic to the manual, then you would have a 100% walkthrough right there. But the rest of what you need is there and very well written.
Old Apr 27, 2007 | 10:43 AM
QuadCam's Avatar
QuadCam
How true!!! For the G, you might as well throw out the manual. I called TXS, and they said "it'll fit, but you have to figure out how to get it in there."
Old Apr 28, 2007 | 08:27 PM
KPierson's Avatar
KPierson
I mounted it at least four different ways in my G35 before it fit well enough to keep the bottom plastic piece. Just take you time, stay calm, bend anything in the area out of the way, and stick it in there!
Old Apr 28, 2007 | 08:30 PM
Audible Mayhem
My350z
i can mount one in a G in under 10 minutes now.... hehehe
Old Apr 28, 2007 | 08:31 PM
KPierson's Avatar
KPierson
It always takes a little longer when its YOUR car!
I wanted some sore of rigidity, as I've spliced quite a few wires in my ECU harness and I don't want any stress on the wires.
Old Apr 29, 2007 | 06:50 AM
rcdash's Avatar
rcdash
If I mount it with the plugs towards the ground, then the rectangular projection sticks towards the glove box and does not let it close properly.
If I mount it with the plugs up, then that rectangular portion that sticks out is higher and does not interfere.
Audible - do you have to modify the glovebox of the G with the ports down?
I don't see any other way. I cut the little bolt off in the back of the G35 that projects out from the firewall (the one up high that is not used for anything) so the UTEC can sit flush back against the firewall and as high up as possible with a tie around the metal chassis bar that goes across the top of the dash.
It's either that or cut off that rectangular projection from the UTEC. Why would they make the unit bigger by doing that???
May 30, 2017 03:28 PM
dcains
Nov 11, 2015 11:36 PM
