ECU reflash.....
Old Apr 10, 2007 | 09:49 AM
Fluid1's Avatar
Fluid1
Originally Posted by nismo14
why would i be happier with a UTEC??? Being that there is no close or good dyno tuning stations closeby..... I'm kinda stuck with just being able to reflash it........ what kinda of downsides can i look forward to.... also what good things are there about a reflash.......
Well, if you can't get to a dyno, then they are all equally useful/useless. Is it likely that you can get gains from a reflash? Yes. Will they be like they would be in a turbo car with a reflash? No. Will it be nearly as good as a dyno tune with a reflash or UTEC? No. Have others done this? Yeap.
Old Apr 10, 2007 | 10:43 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Originally Posted by Chebosto
Technosquare CAN redo the immobilizer: they can erase it, but once you plug your ecu into your car and then insert your own key it will be 'keyed' to your car.
they have a 'spare' ecu program that you can inquire to them about it.. i.e. loaners.
hmm, ill have to look into both!
Old Apr 10, 2007 | 06:22 PM
first350's Avatar
first350
I have AAM's flash and it did exactly what I was looking for:
-good power gains (proper AF, timing...)
-raised RPM limiter
-removed top speed limiter
I also liked them b/c they were super fast in doing the flash...I'm in Seattle; I sent them the ECU overnight, they received it the next day, did the flash, and shipped it back out the same day --> my Z was down for less than 3 days!
here's the post I made: https://my350z.com/forum/tuning/246942-aam-flash-o-dyno-pics-and-vid.html
-Peter
Old Apr 10, 2007 | 06:25 PM
THE TECH's Avatar
THE TECH
Remote flashes don't get my vote. I understand that shops may not be local, but using a generic flash on my car is a no no. Since every car is different, who knows what a flash that was done for another car will work the greatest on your car. This is not to say that it doesn't work, cause obviously people do it, I just don't think it's the best way.
Old Apr 10, 2007 | 06:40 PM
first350's Avatar
first350
from talking w/ AAM, there's not much of a difference between cars when they have the same mods...that's why even if ppl live next to them, they still offer their normal Flash - if someone wants a dyno-tuned flash, AAM can do that; they say that they'll usually squeeze out a bit more power over their regular flash.
Old Apr 10, 2007 | 07:20 PM
THE TECH's Avatar
THE TECH
Just my opinion, but anyone who told me that would never tune my car.
Old Apr 10, 2007 | 07:51 PM
bacalhau16's Avatar
bacalhau16
I have not flashed my 350Z ecu yet, but I did sent the ECU in my EVO to be tuned to turbo-trix, via their mail-in service, and it worked great. I understand that it is always best to have the car put on the dyno and all, but when one is not available, a mail-in flash is not a bad idea! Good luck!
Old Apr 17, 2007 | 09:32 PM
Fooshe's Avatar
Fooshe
has anyone had technosquare do a ecu flash? what was the result? happy? cost? would you recommend it? would you do the flash or take the car there and let them tune it also?
Old Apr 28, 2007 | 10:58 PM
zzerotwosixty's Avatar
zzerotwosixty
Hey guys whats up..... well i have another dilema..... I'm wanting to order the AAM reflash or the tecnosquare reflash for my 05 350Z. So far i have intake... exhaust... plenum etc..... I'm going n/a and i'm wanting an extra something.... Which of these reflashes do you guys prefer???? and is it possible to purchase an ecu off another 350Z to use while my oem one is being reflashed?????
(flame suit engaged)
ECU from Nissan parts=800$. Rent econo-box for three days, less than 60$.
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
