Can you flash the UTEC via the USB port on the UTEC?
Old Aug 27, 2007 | 06:52 PM
QuadCam's Avatar
QuadCam
Default Can you flash the UTEC via the USB port on the UTEC?
I have been having trouble with my throttle for the last month or more. I got the dealer to warranty a new throttle body for me as they were sure that was the problem. well, I am still have the same trouble with it. I would like to flash the TXS throttlecontrol.mot file back onto the UTEC to see if that does the trick. anyways, my old laptop that had a serial port on its docking station....and I can't find the docking station. I have a USB-serial adapter, but my adapter doesn't like uploading anything to the UTEC. I have to use a pure serial connection to get it to function.
My question is can you install the USB drivers that come with the UTEC software and then connect the laptop directly to the USB port on the UTEC for flashing? will it work? also, can you flash just the throttle file, or do I need to reflash the 2.8D version software ,too?
thanks for any input,
Andrew
Old Aug 28, 2007 | 06:26 AM
QuadCam's Avatar
QuadCam
anyone? anyone? Jermaine?
Old Aug 28, 2007 | 07:10 AM
captj3's Avatar
captj3
I think you can use the usb port on the utec. I don't under stand why they have everyone use the serial port. Why put it there if it has no use.
Old Aug 28, 2007 | 02:56 PM
i8acobra's Avatar
i8acobra
You probably have the wrong type of serial to USB adapter. Apparently, there's two types. One type is for PDA's and only has two pins active. You need one with all 9 pins active.
Old Aug 28, 2007 | 03:36 PM
rocks's Avatar
rocks
I used the usb port on my utec when i had it.
Old Aug 28, 2007 | 04:23 PM
QuadCam's Avatar
QuadCam
I do have a PDA one. It is a dynex usb-pda adapter. who makes the "right" one.
Old Aug 28, 2007 | 04:26 PM
i8acobra's Avatar
i8acobra
Dunno. Guy at Circuit City told me that Fry's Electronics has it, if you have a Fry's in your area.
Old Aug 28, 2007 | 04:39 PM
captj3's Avatar
captj3
Go to radio shack or best buy.
Old Aug 28, 2007 | 05:36 PM
QuadCam's Avatar
QuadCam
best buy is where I got the Dynex unit......and now it is discontinued by Dynex.
Old Aug 29, 2007 | 02:36 AM
Lady Jax's Avatar
Lady Jax
Drive For Pole
Default Talk to UTEC with the USB port?
According to the software/hardware manual the USB port is fully functional once you load the USB drivers from TurboXS's website into your computer. We are still waiting for our UTEC from the US distributor so I can't speak from experience, but this is exactly how we intend to communicate with the unit once it is in the car. Let us know if it works
Old Aug 29, 2007 | 03:14 AM
QuadCam's Avatar
QuadCam
The USB port works for normal communication. I have just not verified that it works for flashing the UTEC with new software.
BTW, if you ever planning on using the Tuner wideband, you better find a laptop with a serial port or get a good usb-serial adapter becasue that is the only way to communicate with the TUner/UTEC combo!
Old Aug 29, 2007 | 01:57 PM
thommy's Avatar
thommy
I flashed my UTEC over the USB.
No Problems.
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
