Tach output on Dynojet?
Old Apr 5, 2008 | 06:44 PM
whitt1's Avatar
whitt1
Default Tach output on Dynojet?
Where can do fit the tach output to read rpm for a dyno pull.I went to a non import tuning shop and they couldn't find a way to fit tach output wire to show an rpm reference.All they could give me was a max horsepower reading with no rpm reference.
Old Apr 5, 2008 | 06:45 PM
SlideFox's Avatar
SlideFox
Coilpack?
Old Apr 6, 2008 | 05:17 AM
JOEGYVER's Avatar
JOEGYVER
I have an HR but I think the VQ has it too. Pull the plastic engine cover off and on the left side (passenger side) near the top front of the motor at #1 cylinder, look for the wiring harness. Once located, you should see a small loop of wire with black insulation on in (about the length of a coffee mug handle or little less. This is the tach signal. Just put the pick up around this wire as if it were a spark plug wire, you do not need to tap into it. Good luck.
Maybe you do not have to pull the cover, but we did not see it until we did, just look first to save yourself a step.
Old Sep 8, 2008 | 10:21 AM
infinite's Avatar
infinite
I wish I read this sooner, I went to get my car dynoed yesterday and the dyn ops couldn't find the signal on my HR.
m_0g
Jun 3, 2021 10:05 AM
B Esquire
Sep 24, 2015 07:52 AM
Killermove
Jun 14, 2011 07:38 PM
insaneamine
Feb 19, 2003 01:20 AM
ganz
Jan 26, 2003 12:48 AM
