Reflash????
Old Apr 9, 2008 | 03:08 PM
Control 350z's Avatar
Control 350z
Default Reflash????
should i get a reflash? here are my mods
JIC Hard Tie Rod Ends
Cusco 35mm Front Sway Bar
Cusco Rear sway bar 22mm
Tein Hood Dampers Nissan
AAM Spec Angled Intake Plenum Spacer
Injen cold air intake
Stillen engine dampener
Cusco Camber Upper A-Arm
Eibach pro kit
Top speed 3'' exhaust
would i benifit from it or should i wait and get headers or HFCs?
Old Apr 9, 2008 | 03:18 PM
Asian Invasian's Avatar
Asian Invasian
wait till u max out the N/a breathing mods, then do it.
Old Apr 9, 2008 | 04:04 PM
CSF's Avatar
CSF
if you're sending it out or getting a custom reflash...then wait
if you're getting a diy reflash, then you can go for it now
Old Apr 9, 2008 | 05:47 PM
Control 350z
thanks guys
Old Apr 9, 2008 | 05:55 PM
boosted99gst's Avatar
boosted99gst
Eibach pro kit
So basically you have a spacer, an intake, and a cat-back exhaust. Although the other mods are nice, they are completely irrelivant to an ecu flash. In my opininon the flash should be the absolute last mod you do. If you plan on eventually getting HFC's and headers down the road, do them first, and then have your car flashed. Reason being a tune should be used to utilized to make the most out of all of your mods. If you tune now, then change your set-up later, your current tune will leave you running less than optimal.
Good luck!
Old Apr 9, 2008 | 10:33 PM
Cannysage's Avatar
Cannysage
since you have a sway bar, I'd almost suggest you do it, but you should wait til you get a lot of breathing mods done.
Old Apr 10, 2008 | 02:52 AM
Control 350z
lol yeah i just coppied what i had off another post and didnt edit it
Old Apr 10, 2008 | 01:41 PM
Chebosto's Avatar
Chebosto
i'd probably wait until you get HFC.
cats and plenum spacer affect the A/F ratio the most.
Old Apr 24, 2008 | 03:52 PM
UpRev's Avatar
UpRev
Best solution is to buy a flash that you can change any time you want and update the tune with any mod you make. That way you're not stuck with a reflash that was for your car as it sat 6 months ago.
You can do a reflash with no mods, maybe you want a race map that runs a little rich so that when you're at the track flogging your car it won't ping or run hot. Maybe you'd like an economy map for when you're daily driving your car (gas prices will only go up from here guys, sorry to break it to you). Then theres always a valet map, thats a good one if you are loaning your car out, or letting someone valet park it.
But lets say you don't want any of those, you want your tune to do the things you want it to. Theres only one company that offers you that ability. We don't just have off the shelf maps, we can offer eTune services, or you can buy our off the shelf product and later on when you have a bit more you can take it to one of our Pro Tuners like eipracing.com and have them build you a specific dyno tuned map for your car.
If you have any questions, feel free to ask.
Old Apr 24, 2008 | 03:55 PM
THE_SCHROED's Avatar
THE_SCHROED
Eibach pro kit
I would suggest the tanabe suspension tuner for those mods. JK
Old Apr 24, 2008 | 04:03 PM
UpRev's Avatar
UpRev
You cheeky monkey!
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
MIAPLAYA
Aug 30, 2004 09:53 PM
mlemieux137
Tuning
15
Aug 2, 2004 05:15 PM
zimbo
Jul 28, 2004 07:56 PM
chaknchngo
Apr 14, 2004 07:50 AM
